Why Can't I Find This Tubing???
Old Sep 30, 2014 | 10:52 AM
Olds Dad's Avatar
Collector of Stray 55's
I see this "corrugated" rubber line on a lot of 50s-60s stuff - this one in particular is for the vacuum operated wiper motor on my '55.
Has anyone ever found a source for this? I've scoured the web and find the 'ribbed' stuff like they use on the A-Body washer hoses, but not this style.
Suggestions?
Old Oct 1, 2014 | 04:53 AM
Olds Dad's Avatar
Nobody?
Old Oct 1, 2014 | 05:36 AM
Oldskeeper's Avatar
I would check with your dad, he should have a source for this type of tubing.
Old Oct 1, 2014 | 05:48 AM
Oldsmaniac's Avatar
Have you tried Restoration Specialties? They list a wire loom material up to 3/4" ID.
Old Oct 1, 2014 | 05:58 AM
oldolds88's Avatar
it's not wire loom,its vacuum hose
Old Oct 1, 2014 | 06:10 AM
Oldsmaniac's Avatar
Ok then, if you did an internet search I would say its not available especially if its specific to an Olds. If Chevy used it you have a shot at repro stuff...
Old Oct 1, 2014 | 06:14 AM
Olds Dad's Avatar
Have YOU tried to get ahold of him?
Old Oct 1, 2014 | 06:17 AM
Olds Dad's Avatar
Yeah - not sure if it's specific to Olds...I don't see any listed in any of the
"Buy a Complete 55-57 Chevy Piece by Piece" catalogs
Old Oct 1, 2014 | 06:36 AM
Oldskeeper's Avatar
Olds Dad, I try but I usually wait for him to call me LOL.
Old Oct 1, 2014 | 07:48 AM
rocketraider's Avatar
Oldsdruid
Gordon, is it in fact vacuum/ washer hose tubing or is it a protective cover like cloth wire loom? I'm not that well-versed on 50s cars but I have never seen any tubing like that.
Worst case buy some similar-appearing cloth wire loom and cover modern vacuum tubing with it. It's like the folks at Ames Pontiac say- "fit and function".
Old Oct 1, 2014 | 07:54 AM
Olds Dad's Avatar
Ditto on not having ever seen anything like it (except on these cars) - It's definitely not a cover / coating.
At this point, my curiosity is driving my search. I'm guessing since this is running the vacuum wipers (off of the aux vacuum pump attached to the fuel pump) that the corrugation was intended as additional reinforcing to prevent the tube from collapsing under higher vacuum...but that's only a guess.
Pat McClelland
Dec 21, 2014 03:49 PM
Octania
Sep 17, 2014 05:11 PM
74sprint
Suspension & Handling
Sep 11, 2014 11:37 PM
at3reg98
Jun 4, 2012 12:03 PM
johns59super88
Jun 2, 2012 03:11 PM
