Where to order a radiator?
So my lead guy gives me a 911
after work today. His 99 Chev 454 pu
quit on him.
We deduced Napa battery shot after 3 yrs.
Took him up for the pro-rate on a 6 yr, not bad. $53.
Get back to the truck and I notice MY shortbed is
leaking green on the drive way.. Hmmm.
Come to find out it has developed a small crack on
the very top, left of the inlet hose, before the top plate, damn.
Well, I had already had it rotted out and figure with those stupid
PLASTIC end tanks and being aluminum anyway, where can I get
a deal on one? That's where I need your thoughts guys.
The truck is a Chev 4.3 5 speed with a 4.3 V-6 and air.
Any thoughts as to quality and price. I would like to
find one with copper tanks, but probably not going to happen.
quit on him.
I have used Proliance Radiator. If you Google it, you will get to Amazon. I bought one with metal tanks for my 89 3/4 ton Suburban and it was perfect fit, just like OEM and keeps the 454 at 180 degrees. Also got one for my 72 Cutlass with same results. I would avoid the plastic tanks, especially on one of our older cars.
All great suggestions guys, thanks.
I used the trick that I used on the
crack in the oil pan.
Two small dimples at each end of the
crack, then cut a trough the crack with my drimmel,
fill with JB weld. Time will tell. Nothing ventured
nothing gained as they say. Will post results.
Well, no bueno. Oh well, worth a shot.
Got it to a slow seep after about 40 miles.
Visited with a nephew this weekend, he had
a little Ford that he used fiberglass on and
it worked for him.
Could not find a direct fit unit with copper tanks
so I ordered a Spectra lifetime warrented for 149.00
out the door from A.Z. It will be here in the morning.
it worked for him.
