Where to get custom aerosol paint for plastic?
Old Sep 15, 2012 | 11:35 AM
59-59-59's Avatar
Im having a tough time trying to find someone that will mix a custom color I have into an aerosol can. But I need the paint specifically for plastic. And two cans will be more than enough for what I'm doing. I've seen crazy prices like $75 for mixing paint and a minimum of 5 cans which meant on the area of $140. Any ideas where to go? Thanks
Old Sep 15, 2012 | 12:02 PM
Funkwagon455's Avatar
You can have the paint mixed at your local automotive paint dealer to the color you like in the amount you want. Then buy a Preval paint charger from your local home improvement store, or sometimes the paint supplier will sell them. They are easy to use, inexpensive, and can be cleaned with solvent and reused if the charge is still good. I 've had very good luck with painting interior parts with them.
Old Sep 15, 2012 | 05:53 PM
Tedd Thompson's Avatar
Have you thought of getting a plastic primer in what ever color that is available then re coat with regular paint in your color, remember you are only painting the plastic the first time all other coats are paint over paint. Krylon and Restolum both make this primer in spray cans, XIM makes spray cans and a spray able product....Tedd
Old Sep 18, 2012 | 06:25 AM
mike's88's Avatar
Go to SEM s website. They have a search tool for jobbers in your area, that can mix their plastic/vinyl paint and put it in cans for you.
Old Sep 18, 2012 | 06:37 AM
501Paratrooper's Avatar
x2 on SEM
1hazzard1
Dec 2, 2014 08:40 AM
bigoldscruiser
Jan 10, 2014 11:25 AM
Allan R
Jul 2, 2011 10:01 PM
guycaso
Feb 1, 2011 12:27 PM
awspeich
Feb 23, 2007 12:50 AM
