when did painting become so expensive?
I have been pricing around my area to get my cutlass repainted. The only rust on her are two small spots in both rear quarters. I've even volunteered to pull all of the chrome beforehand. The prices that I have been quoted so far have been enough to make me wonder if I'll ever bother having it done. The quotes have ranged from $7,000 to $35,000.
As I've said before, she's a driver, not a show car. When did having a car painted equal out to a year in college for one of my kids? I know I'm getting older, but I don't ever remember it being this expensive.
not directly labor cost but the shop has to recoup their money for those environmentally friendly expensive paint booths, disposal costs, etc..
Yes, I can't argue that. Still, labor costs have gone up significantly in the last 10-20 years, not only due to overhead costs. Health insurance, liability insurance, etc, etc.
When I painted my Chevelle, I think the gallon of Ditzler lacquer cost me $35.
Even though material prices have gone up a bit since then, I would never pay someone else to paint a car - hell, if I go out of my way to spend a day troubleshooting so that I can spend $10 on a repair instead of $200, I'll certainly go out of my way to spend the time to paint my own car for $1,000, rather than spend $10,000.
It's a lot of patient work sanding and messing around, but it's not particularly difficult.
I also paint my own cars, I buy primer and paint from NAPA, cost is around 1000 in total , but you need masking tape, paper masking, and sandpaper. The last one I did with everything to do the job was 1400.00. But I also spend 6 months working on body before paint.
I am going to try to learn to paint. I have a one car garage I want to turn into a booth, I'll get good equipment, good paint, and practice on some spare panels a bunch. Many many guide coats and block sanding. I wonder how good I can reasonably expect?
And todays materials take a trained knowledge, technique unless you want a low budget paint job. Aint no joe schmoe off the street going into a paint shop anymore and buying lacquer. Them days are looooong gone.
when it comes to paint you have to think long term. what is the cars use? how long do i plan on keeping it? a good quality paint job should last decades. take a 10K paint job and think of it at a 20 year investment. thats only $500 a year. not bad if you ask me. now take a paint job with cheap materials and inexperienced labor...may look good for 5 years and thats it.
I just bought material to paint my 70 Chevelle SS, here is the cost for Dupont paint and clear. Figure another $7-800 for primer, tape, sandpaper, fiberglass, etc. I'm looking at at least $2k for materials alone. If you want the good stuff it cost $$$$.
Yes, today's BC/CC paints take more skill than lacquer, but ASSUMING one can follow directions, it isn't that difficult. Since you can't color sand the base coat, application technique is important, but frankly, it was important when shooting candy lacquer, or even metallic, so that's not really new. Yes, you can't really sand out the bug that lands in the paint when you're doing a garage shoot, so a plastic sheet spray booth with a fan and filters is important. Proper prep, temperature, and humidity control is important. None of this is new, nor is it especially difficult. Like rebuilding a Qjet, it just takes care and attention to detail.
Even ASSuming reduced prices for larger quantities, that's about $600 a gallon.
For lacquer!
I had believed that most of the price increase was because of the newer formulations and processes, but I guess some of it is just plain more expensive.
Good to know you can still get lacquer, though - I hadn't realized that!
Thanks!
You can still get lacquer, but the largest container you can buy is a quart. TCP Global, HOK, and many others still sell lacquer that way. Of course, the total cost for the 5-6 quarts you'll need will be higher than if you could buy a gallon.
I expect I'll probably do a "real" painting job again in about five years or so.
I'd better start robbing banks now.
You may be overstating it a tad...
I have two really good friends that work at separate shops and both had to go to classes to learn the newest paint systems. thats what some of this stuff is now..a system. its like being a pharmacist in the sense that you have to know what interacts with what and what possible unintended side effect could result. Mixing is a huge part of it.
everyone keeps saying its not difficult... NO its not like designing a structure using complicated math formulas but its tedious, takes an experienced hand, is labor intensive, it HARD on your body, etc.. Again, it comes down to what each person thinks looks good. some people are perfectly fine with 10 footers. getting a quality paint job is hard work.
I have seen a car painted black with water base, I was blown away, it was deep looking, by far a show paint job. the owner would not say what it cost. I know that shop has switch every thing over to water, cost a fortune , new booth , pluming, hoses, guns. And they stopped restoring cars, and only do insurance clams now. The owner said they can fix four or five fenders a day and repaint just that, and make way more money then restoring some ones car over a year . So I can see where restoration shops can charge so much, there just not that many around that restore whole cars.
I repaired my sons Mustang aluminum hood and plastic welded the front bumper guard that was cracked in multiple places. Then prepped and painted both. It took me 3 days and $400 worth of supplies. I respect the paint/body guys, its hard and tedious work. Although the hood didn't come out as good as a professional its fine for a daily driver.
I looked into stripping all the trim off the Cutlass and doing most of the body work, then letting a Maaco paint center prep and paint it. I've seen their work and its quite good. It was a reasonable price. Ultimately had a friend paint it, its not perfect but very nice for what I use it for.
I do my own. Dad taught me and I'm glad he did not only because of the costs involved. But because of the countless paint shop horror stories that are out there. None of my cars are perfect. But I can say that I did them myself.
My success came from using higher end materials. One car is a pearl job and the other is a pretty heavy metallic. I went top shelf on materials for both jobs. I didn't want to have to figure out how to mix the stuff (pearls and the like) to make it consistent.
I also went to a seminar put on by House of Kolor, sponsored by my local paint supplier before I did the first car. I learned some great tips there that have really helped.
When people look at the first car, they ask me who painted it. I tell them I did it and it was my first attempt and they look at me like I have three heads.
I took the mistakes I learned on the first car and applied it to the second car. When people ask who painted that car, I tell them I did and they want to know where my shop is.
I'm not a professional. Both cars were painted in a standard, detached, two-car garage with an exhaust fan in the window.
#31
#32
#33
Report: Federal regulations costing US $1.9T annually
The federal regulatory cost reached $1.885 trillion in 2015.
Federal regulation is a hidden tax that amounts to nearly $15,000 per U.S. household each year.
In 2015, 114 laws were enacted by Congress during the calendar year, while 3,410 rules were issued by agencies. Thus, 30 rules were issued for every law enacted last year.
Many Americans complain about taxes, but regulatory compliance costs exceed the $1.82 trillion that the IRS is expected to collect in both individual and corporate income taxes from 2015.
#34
Interesting that I just read this article today:
#35
I painted this car around 7 yrs ago. It was the first car I ever painted. I had guidance from an experienced body man. I rented a crappy little paint bay from a body shop that a fellow Olds enthusiast owned. It was Sherwin Williams BC/CC. I still spent 2k-2500k on just the paint and associated materials.
I will do it again when it comes time. Thats what I love about this hobby, I can learn as I go and if I don't have the equipment or knowledge to do something I pay someone who does. I save $ where I can and know when I'm in over my head.
https://classicoldsmobile.com/forums...971_olds-2.jpg
#36
i did the same as koda. was my first attempt at painting . pretty happy with the outcome .yeah you can tell its not professional but then again i restored the entire car for the cost of a professional paint job .this is a driver also.
#37
http://www.williamwolf.com/
#38
I did my own, had to save money and it was important to me to do it myself. Did not expect more then a 10-20 footer. Used single stage white, epoxy primer. Cost less then @ 1500, including a Finish-line 4 paint gun. Others will tear it apart, but I don't care. Anybody with money can pay somebody else to do it all for them. Most paint jobs on older cars are way better then how it came off the line. Some BC/CC jobs I have seen don't look good on older cars. I don't expect it to be exposed to the elements 24/7 for the rest of its', or my life either. Had some experience shooting SW acrylic enamels in the 70s. Researched and read all I found beforehand.
What surprised me was the difference in prices by color. I think white was the cheapest, red the most expensive.
Do what you can do and afford, then get the car out and enjoy it and the hell with the snobs and naysayers.
#39
But it is a bargain compared with the cost of letting industry run amok as it was in living memory. Take a look at Dehli in India or many parts of China to see what can happen.
Roger.
#40
There is a distinct difference between protecting the environment and being a controlling entity hell bent on the destroying the countrys ability to produce good and services. Also control of the people by killing off industries and making them depended on the government in order to secure their votes. if given the choice between jobs for the people so they can feed their families and the environment...well i'm taking my chances that mother nature is gonna do what she does regardless, i'm picking jobs for the people.
you can be responsible with the environment with having strangling regulations.
