Whats wrong with my 307?
Old Feb 10, 2019 | 08:16 AM
87Brougham307's Avatar
I just installed a new ps belt because the old ripped in 2 pieces.After i cranked her up with the new belt,it squeals as hell and the belt is getting ultra hot so the ps pulley itself too. Somebody had the same problem? I dont know what to do.A new ps pump or just the pulley?
Old Feb 10, 2019 | 08:32 AM
It's not the belt, although you need a new one. Spin the ps pump by hand, if it feels rough, time for a new pump.
Old Feb 10, 2019 | 08:34 AM
A broken pump can make the belt gets so hot?
Old Feb 10, 2019 | 08:50 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have never seen a PS pump go bad but I would check it closely. Is the A/C belt still in place? If not, it will squeal and burn the power steering belt right off, too much load for one belt driven off the crank.
Old Feb 10, 2019 | 08:55 AM
The ac belt is off, but the compressor is still on. Since 2k miles the ac belt is off and now it squeals as **** and the ps belt gets to hot to touch. Im so frustrated and dont know where to start. You think first try with ac belt on?I would unplug the compressor and use just the pulley for more balance on the diagram right?
Old Feb 10, 2019 | 09:28 AM
Yeah. This is elementary engineering. A belt just doesn't "get hot," it has to get the heat, which is energy, from someplace. It's going to get warm just from the combustion heat from the block, but, if it gets hot, you have friction someplace. Unless the belt is grossly deformed, or the pulley is, you are getting the heat from a failing bearing in one of the pulleys. This is why I said to take the belt off, and turn the pulley pump by hand, to see if its bearing is going out.
Do you understand now?
Old Feb 10, 2019 | 09:32 AM
As we had all the belts off we turned the pulleys and they were all good,spinning as they should be thats why the mechanic said its the ps pump. I red now that 307 without a ac belt on can squeal also so im gonna put a ac belt back on and check again. If it still squeals what should i get only the ps pulley or a new pump?
Old Feb 10, 2019 | 09:56 AM
If nothing is binding, then the belt wasn't tight enough.
Old Feb 10, 2019 | 12:45 PM
rustyroger's Avatar
'87 Delta 88 Royale
I agree with (other) Eric. the p/s belt needs to be very tight, much tighter than the alternator belt.
As I recall from my 307 powered Cutlass the a/c and p/s were driven directly from the crankshaft pulley, and the alternator from another pulley on the water pump.
If the p/s belt is doing all the work and isn't real tight it will slip.
If you don't want the a/c you can swap in pulleys and belt from a non a/c system with the alternator driven directly from the crankshaft pulley.
Roger.
Old Feb 10, 2019 | 12:50 PM
Roger.
I just bought the belt and im on my way home. Wish me luck. Ill post a update.Thanks
Old Feb 10, 2019 | 02:21 PM
Is it time for another belt squealing thread? Once again, be sure you tension the PS pump properly.
https://classicoldsmobile.com/forums...lt-squeal.html
Old Feb 11, 2019 | 09:33 AM
rustyroger's Avatar
'87 Delta 88 Royale
About the right time of year Joe. When Spring arrives attention will be turned to oil and filters, pest damage on winter stored cars, radiators and fans are due when the hot weather arrives....
Roger.
kansjfr
Oct 19, 2014 10:38 AM
Johnny Cage
Feb 27, 2013 12:34 PM
vistacruiser1971
Tech Editor's Desk
16
Jul 8, 2012 10:41 AM
Eclipse_the_Wagon
Aug 7, 2011 08:14 AM
1low88
Jan 15, 2010 07:17 AM
