What Temperature gauge is better?
Old Sep 19, 2012 | 04:55 PM
Al Sanchez's Avatar
Okay..I'm ready to order some new Gauges to put in my new cluster... I need help on witch one should I order should I get the 120-240 or the 140-280 degree... Would the thermostats play a role on witch one to get it hade a 190 degree and I just replaced it and put a 180 degree.. What's your guys opinion
Old Sep 19, 2012 | 06:28 PM
m371961's Avatar
In my opinion, it does not matter. I would not run a engine at 240 for very long.
The other question, are you going with mechanical or electrical? I do prefer mechanical.
Old Sep 19, 2012 | 06:36 PM
Al Sanchez's Avatar
Yeah.. I prefer mechanical also and I'm leaning towards the 120-240 so if I see the needle all the way up I might still have time to pull over and not do any damage as if I catch it all the way up at 280 it might be too late.. Damage done
Old Sep 19, 2012 | 09:29 PM
ah64pilot's Avatar
For my cars, if the needle hits 220 it's shutoff time. I don't know who would need a 280 degree temp gauge...go for the 120-240.
Old Sep 19, 2012 | 09:35 PM
Al Sanchez's Avatar
120-240 it is thanks picking them up tomorrow and see how they look on that gauge cluster I got for them..
Old Sep 20, 2012 | 05:47 AM
m371961's Avatar
If you have 2 ports to access the cooling system, use one for the guage and one for the idiot light.
Old Sep 20, 2012 | 07:19 AM
Al Sanchez's Avatar
Yeah I'm planning on doing that it will be nice to have the dummy light give me a heads up if it starts getting too hot.. Quick question.. For the oil pressure gauge do you know if there is two ports? I don't want to disconnect that dummy light either.. Or do you think I can some how add a "T" fitting and tee off it??
Old Sep 20, 2012 | 08:40 AM
455man's Avatar
Put a T in there. That's what I did. Came in handy on my old worn out 350. Sometimes at an idle while hot the idiot light would come on.
Old Sep 20, 2012 | 08:46 AM
ah64pilot's Avatar
Exactly! Get a 1/8" NPT X 1" (if you can find it) or 2" brass pipe, and a 1/8" NPT "T" fitting.
Put the pipe where the sender goes into the block, then screw on the "T" so the short side is perpendicular to the pipe. Put the gauge in the side of the "T" and the sender in the top side. Works like a charm
Old Sep 20, 2012 | 08:53 AM
Al Sanchez's Avatar
Okay cool so I will "T" off of it.. Ok now for the third Gauges I'm going with the vacuum gauge instead of the voltage.. Does anyone know the best place to hook that one up too..
Old Sep 20, 2012 | 12:09 PM
Al Sanchez's Avatar
Okay got the Gauges in.. Looking good now going to go buy some fittings and I will be installing them later on today.. Cross my fingers everything goes smoothly
Old Sep 20, 2012 | 12:26 PM
ah64pilot's Avatar
Man that looks so good! Where did you get that gauge console?
Old Sep 20, 2012 | 12:36 PM
Al Sanchez's Avatar
Ah64pilot I got this one on ebay but I think the guy who makes them is a member of CO also and he makes a lot of different styles and sizes you should try to look him up and see his stuff pretty good I can't remember. His name try searching similar trends and see if something comes up ill try to look in a bit .. I'm on my way to the store to get those fittings you game me some good advice on the oil pressure.. Question should I get the vacuum for my vacuum gauge from the intake or the bottom of my card..???
Old Sep 20, 2012 | 12:48 PM
455man's Avatar
I'd think either place would work as long as it's manifold vacuum. I'll assume you meant Carb.
Old Sep 20, 2012 | 12:49 PM
ah64pilot's Avatar
I would get it from the intake manifold because it probably has a 1/8" NPT fitting that goes to the gauge doesn't it? If you go to the carb you'll have to find the manifold vacuum port and even then it won't be a threaded fitting it'll just be a pushed on hose.
Old Sep 20, 2012 | 12:56 PM
RetroRanger's Avatar
72 Olds CS
Pilot heres the housing seller
https://classicoldsmobile.com/forums...-housings.html
UN = w70442 AN = randy
Al
you can get the vacuum from the carb or manifold, if you use the carb just be sure its manifold vac not ported....if its ported vac you will only get a reading off idle
Old Sep 20, 2012 | 01:30 PM
Al Sanchez's Avatar
Thanks guys I'm going to do my best to get it from the intake
Old Sep 20, 2012 | 02:29 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
On the oil pressure gauge,I would not use the plastic tubing that comes with it. Autometer sells an upgrade kit that contains copper tubing instead of the plastic.
If that plastic tubing melts or breaks you will not be happy with oil all over your engine compartment,interior or under your dash.
Old Sep 20, 2012 | 02:42 PM
Al Sanchez's Avatar
Thanks w30-dreaming I was just looking and reading on that.. It's like you where reading my mind.. I'm going out on a hunt to the local auto parts store and see if I can find some..Because you are right that plastic one don't look like it's going to handle the jod especially with it going across that hot engine
Old Sep 20, 2012 | 02:44 PM
Your welcome Al.
Walter
Old Sep 21, 2012 | 05:33 AM
72 Olds CS
I picked up the copper tubing kit to repalce the plastic line on mine at advanced auto
Old Sep 21, 2012 | 07:23 AM
455man's Avatar
I learned the hard way. Got oil all over my feet while I was out of town and had to drive from store to store to find someone with a plug. Good news is the floor did not rust
Old Sep 21, 2012 | 09:11 AM
Al Sanchez's Avatar
Yeah copper line is the only way to go found it at autozone 12 dollars not bad.. I think I have everything I need I will install them and try to post pictures of the finish work
Old Sep 22, 2012 | 02:38 PM
Al Sanchez's Avatar
Okay everything went smooth. Thanks everyone.. Here is the finish work.. Nice
Old Sep 22, 2012 | 05:37 PM
72 Olds CS
Looks good Al I like the guage choice
BTW I sold my vert
Old Sep 22, 2012 | 05:55 PM
Al Sanchez's Avatar
Thanks for the complement on the Gauges.. Glad to hear you sold the vert all complete. I hope the new owner brings it back to life.. Mine was a theft recovery and when I bought it my wife went crazy she did not see the potential I told her I could not see a 1972 cutlass supreme convertible go to waste she said I would never bring it back to life.. Now she admits its a very beautiful car and she loves driving it.. Only when I let her..
Old Sep 22, 2012 | 06:02 PM
ah64pilot's Avatar
Looks good! Almost like it was put there from the factory Now you gotta get some new wood grain for the dash because your gauge pod is making the factory grain look bad lol!
Old Sep 22, 2012 | 06:14 PM
Al Sanchez's Avatar
That's. Just the reflection from the light I hade to use the bright up the inside since of the car it actually matches pretty darn close to the original witch I will never replace I hade some friends over and they asked if that was an original part I was like yeah .. There where chebby guys..
Old Sep 22, 2012 | 06:19 PM
ah64pilot's Avatar
Glad to hear it's a lighting / camera thing...those wood grain stickers are pricey! I still haven't gotten one for my dash. My original was coming off so I took it all the way off to paint the dash.
Old Sep 22, 2012 | 06:28 PM
Al Sanchez's Avatar
Pilot you have 2 beautiful cars I seen them on you tube.. Mine is on YouTube under vettulose1972.. I been wanting to ask you how did you get that drawing of your two cars on your avatar looks cool sort of a oldschool black and white with color look
Old Sep 22, 2012 | 06:31 PM
  #31
ah64pilot's Avatar
Well thank you! I appreciate it...here is the link for the cartoon website. Scott (GAoldsman) had posted some pics in the *New* Good morning thread.
http://www.cartoonize.net/
Old Sep 22, 2012 | 06:40 PM
  #32
Al Sanchez's Avatar
Thanks pilot.. I cartoonists a picture of my wife she was ... I was
Old Sep 22, 2012 | 06:41 PM
  #33
ah64pilot's Avatar
LMAO! I should try that
BTW, your car is super clean! I love the color! Very nice! I don't have to tell you not to get grease on your seats, oh brother I hate white interior for that! It looks good when it's clean but geez it sucks when it gets dirty.
Old Sep 22, 2012 | 06:53 PM
  #34
Al Sanchez's Avatar
Don't. Remind me on white seats when my 2 and 4 year old's are jumping all over my seats my wife be like you just going to let them jump all over your car like that.. So I tell her I can always replace the seats but I can never replace. My kids
Old Sep 22, 2012 | 07:17 PM
  #35
ah64pilot's Avatar
Awe man! I'm the exact opposite, I can make another kid...I've got to pay to have the seats fixed lol! But my kids know better...I don't really have to get onto them.
Lady72nRob71
Oct 6, 2019 07:24 AM
1carsick
Sep 9, 2013 04:29 AM
Nickthefish
Jan 27, 2013 10:47 AM
69'442
Feb 20, 2012 05:34 PM
tpawlik
May 16, 2011 05:06 PM
