What Sources for Rubber A-pillar/ Post Seals Do Cutlass And Vista Cruisers Use?
These are the rubber seals between the leading edge of the front doors and the a-pillar rain gutter piece. The seal is glued to the interior a-post sheet metal cover and sandwiched between the cover and the a-pillar.
I looked at Fusick, Restoration Small Parts and Metro Molded Rubber, but couldn't find any. What do you use? Is there anything by the foot?
Do you want just the rubber? I have a set, found the set but only one has the rubber on it. I probably still have the other, but would have to see if I can find. 442 Harv
Thanks guys, but I would prefer new since mine are ok, but slightly hardened and cracked. Harv, do you mean you have a set including the sheet metal covers they're glued to? I really only need the rubbers. Are yours new or very good? I'd be surprised if such a fairly simple rubber profile isn't available somewhere by the foot...
Mine are cracked and maybe a little bit torn. If I can't find new rubber I'll talk to you about your used ones. Thanks for looking into it and of course to Scott too...
