what pressure rad cap ?
Location: from Wisc, then Texas, then Kansas, now back to Texas,
new motor , has a tendancy to run hot a little at extended idling............but otherwise normal 350 motor , small cam, 10.25 flat tops, 2 bbl carb ....what size rad cap should I be useing ? I have 13 lb used one on it now and it started to leak. what should I replace it with ? What is normal or standard size ?
capstoneclub
December 27th, 2020 02:24 PM
Cutty69
October 4th, 2013 09:38 AM
