Did a 70-442 w/4 row radiator come factory with the large ears rad cap?
Old May 2, 2015 | 06:18 PM
capstoneclub's Avatar
Old May 3, 2015 | 10:15 AM
Not sure what you mean by "large ears rad cap". If you mean were the extensions on the side different than 2 or 3 core radiator top plates, yes.
Standard radiator top plate for 3 core with HD cooling
4 core radiator top plate (70-72)
Old May 3, 2015 | 12:13 PM
68442's Avatar
To my understanding the RC15 large ear cap was used up through 72. 73 on used the small ear cap.
Old May 3, 2015 | 12:45 PM
Sorry, I am referring to the actual rad pressure cap (not the rad top plate cover).
Note two examples of large ear vs small:
File Type: pdf
File Type: pdf
Old May 3, 2015 | 12:51 PM
I thought the large ears went thru at least 1970
Old May 3, 2015 | 01:37 PM
You very well could be right. I'm sure someone who has a 70 442 will chime in. I did find some info about them that is likely carried over between brands. Possibly one of these vendors knows as they manufacture them?
http://www.heartbeatcitycamaro.com/s...968-1969-1970/
http://www.autometaldirect.com/chq-r...ap-p-2464.html
Old May 3, 2015 | 07:37 PM
mrolds69's Avatar
It should have a large ear cap like #2 in capstones pics. There are not really 2 options, one is correct for 1K point judging and the other MIGHT slide by depending on the judge. Nothing wrong with the small ear cap, you can use it, it works, it was the over the counter replacement for the big ear cap. This is a case where both items can be "NOS" but you can lose points at a point judged show. Personally...if I'm judging...I would rather see a large eared repro, than a small eared "NOS".
Old Dec 26, 2020 | 09:46 PM
Bigmikey65's Avatar
No clear answer - or photos - from this past post either.
Old Dec 27, 2020 | 06:33 AM
VC455's Avatar
Barely Registered
My three 1970 GM cars were born with the large ear caps.
Old Dec 27, 2020 | 02:24 PM
Pretty funny, I forgotten about this question on this old thread. Sounds like the 1970 442's at least still came with the big ear design. I have seen some people go back and forth around whether the solid rivet design was used vs the slightly dimpled/depressed rivet vs the fully depressed rivet. I am pretty certain that cars from 68-69 used the fully depressed or hollow rivet design. Possibly that changed into the slightly depressed rivet design for the 1970 year? I could see that being something that could have changed at some point during the 1970 production year as occurred on other very hard to notice little things, possibly from factory to factory? Again, not 100% certain
imawagonholic
May 15, 2019 08:51 PM
62radarlove
Nov 7, 2012 03:45 PM
skryla
Dec 18, 2011 09:45 AM
Indy_68_S
Nov 24, 2010 07:52 PM
nelsontj
Jun 16, 2010 03:48 PM
