What frames will fit?
Old Nov 3, 2012 | 08:59 PM
raw442's Avatar
Question What frames will fit?
I've got a 1969 Olds 442 and I need to put a different frame under it. I thought I had a good frame from a 1971 Cutlass, but discovered today that it is no good as well (rusted bad behind the front body mounts). I did pull the disc brake set up from it though. But what I need to know is what frames will fit. I think it is all GM (Chevelle, GTO, Skylark, Cutlass, 442) from 1968-1972, is that correct? Do any other models like Grand Prix or Monte Carlo fit? Also will a frame from a 4 door work?
Old Nov 3, 2012 | 09:18 PM
Rickman48's Avatar
Believe the GP + MC have the same WB, but are extended in the front.
4-dr is a longer WB, as is a wagon.
Old Nov 4, 2012 | 06:51 AM
The 69-72 GP and 70-72 Monte have a longer wheelbase than other A-body 2drs and the frames are different.
2dr Holiday and Sport coupes use 112" WB
Convertibles use 112" WB boxed frame
GP and Monte use 115" (?) wheelbase
4dr and flattop wagons use 116" WB
Vista and Buford SportWagon use 121" WB boxed frame
Old Nov 4, 2012 | 07:12 AM
raw442's Avatar
Thanks for the info guys!
Joel n
Nov 19, 2007 01:48 PM
MAGIC253
Jan 2, 2007 04:32 AM
volivar
Oct 15, 2006 10:17 PM
<ohio2atl>
Jan 28, 2005 11:38 AM
