What do these wires go to
Old Nov 7, 2020 | 04:01 PM
benbarberco's Avatar
Old Nov 7, 2020 | 04:41 PM
TimMC's Avatar
Need more info on car to know for sure , but kind of look like aftermarket stereo wiring.
Old Nov 7, 2020 | 04:42 PM
You were provided with an image of the wiring diagram.
You’ll need to read, review and follow the wiring diagram. I have suggested to you previously to buy the CSM where you will have a paper copy of the color coded wiring diagram. I suggest you buy it.
https://classicoldsmobile.com/forums...6/#post1261841
Old Nov 7, 2020 | 07:55 PM
it’s 72 cutlass
Old Nov 8, 2020 | 06:03 AM
The out of focus square connector with the white, orange, and grey wires is the feed for the console.
Yellow should be the power feed to the original radio. It should have +12V with the key in RUN or ACC.
Solid orange should be the power feed for the dome and courtesy light circuit. It should be +12v at all times.
The wire with the single clear connector is too out-of-focus to tell what color it is. Is it grey or tan or pink? Grey would be the feed for the illumination (instrument panel lights).
oldcutlass
Jun 5, 2022 03:01 PM
j808702
Oct 31, 2016 07:50 PM
WolfmanG
Jan 16, 2012 03:26 PM
bonezarally
Jul 26, 2011 04:45 AM
442much
Aug 9, 2010 09:11 PM
