what do i have?
Old March 4th, 2011, 07:10 PM
70cleansupreme's Avatar
what do i have?
ok, i bought a 1970 cutlass it has power windows and it has a spot where it used to be a manul, now its auto. there is some supreme logos in the dash. is there a way to tell what i have by the vin? A guy after i bought it offered more then 2 times what i payed for it and asked if i kne what i had, but he wouldnt tell me the vin on the dash is 33687LAN450090
70cleansupreme is offline
Old March 4th, 2011, 08:22 PM
vette442's Avatar
The VIN wil not tell you anything in 1970, but a factory 4 speed floor hump will. Does the old shifter area on the hump look like the pic below or does it have evidence of once having the hump? If so, it was once a 350/M20 or 350/M21 car, a fairly rare beast. There are other tell-tale signs, but the hump is probably the most obvious.
Despite the Supreme logo on the glovebox door, the 33687 VIN shows it to be a V-8 Cutlass holiday coupe (fastback body) and not a Supreme (notchback hardtop). It's not a 442 either. Have any pics?
Terry
vette442 is offline
Old March 4th, 2011, 10:36 PM
With a Buick motor in it?
That's just weird.
And it's definitely not a Supreme .
MDchanic is online now
Old March 5th, 2011, 05:31 AM
stlbluesbrother's Avatar
Originally Posted by 70cleansupreme
... the vin on the dash is 33687LAN450090
These characters sound like they are from the cowl plate, not the dash VIN. What other info is on the cowl plate? It will indicate if the car had bucket seats or a bench. I think some W-31 cars had a bench seat AND manual shift.
stlbluesbrother is offline
Old March 5th, 2011, 05:45 AM
Registered
Bluevista's Avatar
The guy wouldn't tell you huh?
I'd drive that guy off while wielding a bumper jack and when he's running away I'd yell "I know I got a car that you'll never own!! You miserable #@^%$#$@^!!!" .
Bluevista is offline
Old March 5th, 2011, 06:15 AM
allyolds68's Avatar
A guy after i bought it offered more then 2 times what i payed for it and asked if i knew what i had, but he wouldnt tell me the vin on the dash is 33687LAN450090
There's nothing he wouldn't tell you that you can't get from the members on this board unless he happens to have paperwork for the car.
allyolds68 is offline
Old March 5th, 2011, 06:46 AM
Not just W-31s. You could get the 4 spd (or even the HD 3 spd with floor shift) in just about any A-body with a bench seat. Even the 442s had a credit option to change the standard bucket seats to a bench, even with a manual trans.
joe_padavano is offline
Old March 5th, 2011, 07:14 AM
for some reason it wouldnt let me put a pic in a reply. So i upload some on my profile. i only paid 1200 bucks for the car it runs and drives like a top, the guy told me the motor had been rebuilt 40,000 miles ago, the motor makes no noise what so ever sounds clean and helth and strong, shifts perfect.
Old March 5th, 2011, 08:22 AM
Indy_68_S's Avatar
So what's the VIN ? Its on the dash and on your title. The number you posted looks like the body number from the cowl tag.
Any other info about "it has a spot where it used to be a manual " ? Do you mean the hump ? Or ?
Might also be helpful to check the block/head numbers...
Facing the front of the engine, at the top surface of the timing chain area, to the left of the oil fill tube, there is a code about 1.5" high followed by the casting number.
Heads will have a number by the #1 spark plug..like 6,7,8
Indy_68_S is offline
Old March 5th, 2011, 08:34 AM
i was meaning a hump and a hole where it used to be a shift in the floor, it has a buick motor in it now so its no help the vin is 336870m351118, yea sorry your right i had them mixed up
Old March 5th, 2011, 09:17 AM
Indy_68_S's Avatar
Not sure how accurate, but I get...
3 = Oldsmobile
36 = 8 cyl Cutlass (Supreme would be '42')
87 = Basic Hardtop Coupe
0 = 1970
I must've missed the part about the Buick motor....
Any other clues to the original manual ? Clutch pedal still there !?! Z-bar bracket ? etc...
Sounds like it is (was) a pedestrian 350ci Cutlass hardtop when it was born....but others can probably provide more info...
Old March 5th, 2011, 09:56 AM
whats the diff. between a hoilday coupe and just a hard top
Old March 5th, 2011, 10:45 AM
the other numbers on the cowl plate are st70,tr930,d5b,19-19
Old March 5th, 2011, 10:57 AM
2blu442's Avatar
OK, I'm going to take a stab at the other trim tag codes. My reference shows that it came with what Olds called Ebony Black paint and a black interior with bucket seats. Thats the 19 19 (Black on black) and the TR930 is bucket seats. The ST70 is for 1970 and d5b could be 05 = May and B = second week in may (build date) John
2blu442 is offline
Old March 5th, 2011, 11:12 AM
Indy_68_S's Avatar
Nothing....Its just Olds-speak....
Holiday = Hardtop
Old March 5th, 2011, 11:26 AM
ok thanks, did those pics on my profile help any one or give any one a idea about the factory tranny.
Old March 5th, 2011, 11:38 AM
I just took a loot at the pictures and it appears the engine isn't original to the car. The distributor is at the front of the engine, not the rear like 350 Olds rockets.
Old March 5th, 2011, 11:39 AM
pics 101
See if this helps
Pics 101
When you reply make sure you are in “Advanced” If it says post a “Quick reply” hit “Advanced”
Scroll down below the box you type in and hit “ Manage Attachments” A new box will pop up.
Hit “Browse”
The hit “Upload” and wait a few secs for the pics to up load. Then close this box.
Next you can hit “Preview Post and your pictures should be there.
There is a size limit on pics
Jamesbo is online now
Old March 5th, 2011, 12:08 PM
sorry its kinda fuzzy, ill try to get another pic
Old March 5th, 2011, 12:33 PM
heres some more pics, was $1200 a pretty good deal
Old March 5th, 2011, 02:53 PM
Olds Dreamer
alek72us's Avatar
Not a bad deal at all. differant steering column probably because they wanted to see what gear they are in. aftermarket or differant car side mirrors.
alek72us is offline
Old March 5th, 2011, 04:25 PM
I think you got a really nice car for 1200.00
Re: the Cutlass Supreme "badging". It seems that a LOT of people who see the Cutlass "S" automatically assume it means Supreme. Not so. The Olds jewelry that goes with the Supreme is "CS" Cutlass Supreme.
Re: the "hardtop" question. All Cutlass models except the post cars and sedans came as "hardtops". The major difference is the quarter panels and roof lines of the cars. The Cutlass Supreme has a 'notchback' design and elegantly squared rear quarter lines - see below.
The fastback design is typical of the one you own. Note the radical sweep of the roof line as it slopes to the rear. Most commonly refered to as 'fastback'. The quarter panel also has a gentle cresent ridge over the rear wheel, giving a more stremlined racy appearance
Allan R is offline
72olds442
Wheels and Tires
April 28th, 2012 12:59 PM
SMOKEYMTNKUSTOMS
December 26th, 2010 09:51 PM
<lkajdf>
Cars Wanted
June 29th, 2007 02:49 PM
Uk olds
January 25th, 2005 04:49 PM
Buster
July 15th, 2004 07:28 PM
Quick Reply: what do i have?
