What adhesive should I use?
Old December 28th, 2020 | 09:39 PM
724drcutlass's Avatar
I just got this replacement chrome piece between the 2 windows. It attaches to rear window by some type of adhesive. What's the best? Thanks
Old December 28th, 2020 | 09:50 PM
bccan's Avatar
These are/were normally installed with”Tuff Pak” (spelling is suspect), a tacky, butyl coated, cork backed tape or ribbon. Nowadays they are usually installed with the same urethane adhesive that most fixed glass is installed with. Not sure if it is still available but it likely is.
Old December 30th, 2020 | 04:42 PM
Jeff99's Avatar
Use 3m trim adhesive or the super trim adhesive
Old December 30th, 2020 | 05:31 PM
I used a strip of 3M 130C rubber tape folded over the edge of the glass, then pressed the trim channel over the tape/glass for a tight friction fit. I did that back in the mid-90s and it has help up well.
Old December 30th, 2020 | 10:32 PM
Crazy68Cutlass's Avatar
I posted a similar thread. Here is the response i got.
They don't use adhesive, they use a kind of rubber mounting "tape". It doesn't have any adhesive on it, it's a friction fit. You wrap it around the front of the glass & carefully tap the chrome molding onto the glass, trim the excess with a razor blade, then slide the verticle weather strip in place. If you have a good glass shop in your area they should have some, There's 2 thicknesses of the tape, our cars take the thinner of the 2 I believe. I had my local glass shop do mine, it cost me $5. The Parts Place does sell some pre-molded pieces for $8 a pair. They're in the "exterior moldings, mirrors & door handles" section.
Old December 31st, 2020 | 06:29 AM
jharsh's Avatar
This is what you need.
https://www.steelerubber.com/sash-ch...er-70-2169-257
Old December 31st, 2020 | 08:24 AM
Great, thanks guys for the info!
Old January 1st, 2021 | 09:42 AM
70Post's Avatar
Whatever you do don't use any of those preformed rubber channel pieces (which is likely what the piece from The Parts Place is)....they aren't sticky like the glass tape material and may not hold the chrome channel on.
irydasteelhorse
December 29th, 2020 02:13 PM
oldsmobilejim
March 25th, 2020 07:15 PM
Tjohn8573
February 18th, 2020 07:59 AM
Tjohn8573
February 16th, 2020 06:40 PM
JOHNNYOLDS442
May 8th, 2014 02:52 PM
