Water pump question...
Old Jan 13, 2025 | 08:54 AM
Tancuda's Avatar
Hi, is the main difference between 5.1, 5.6 and 6.0" water pump only the location of the fan vs radiator/shroud or the location and flow of water pump ?
Old Jan 14, 2025 | 07:00 AM
Oldscutty72's Avatar
I believe the necks are different depending on the car options. Ac, motorhome etc. I learned the hard way. Ultimately I took the job of water pump to a local parts store and they figured out which one I needed.
Old Jan 15, 2025 | 07:04 PM
Differences in inlet diameter are a function of model year (70-earlier vs 71-later). Impeller differences are a function of application (A/C vs non-A/C). Length is a function of the application and is NOT directly related to A/C or not. For example, my 67 Delta uses a 5.1" pump for A/C and non-A/C application. The factory had two different P/Ns, but the aftermarket replacements are the same for both applications.
Old Jan 16, 2025 | 02:30 AM
Tancuda's Avatar
Thanks Joe, interesting as always
therobski
Sep 21, 2023 12:45 PM
jopa
Jan 11, 2023 10:03 PM
vickycar
Aug 19, 2021 09:36 AM
Walterdurbin
Tech Editor's Desk
May 12, 2016 03:32 PM
J-(Chicago)
Mar 30, 2013 02:54 PM
