water pump build date
Water pumps were cast by the thousands and stockpiled by CFD. You could get one that was built months before the car. Suffice to say if the CFD date is after the build, you likely have a replacement part.
Similar concept to engine blocks and intake/exhaust manifolds.
Probably not what you were looking for in an answer.
Check your cowl tag. The build date on it will be the date Fisher Body works started welding your car body together. Once that was done they installed the interior components like dash, glass, etc. Then the car was sent to the assembly line where it recieved its frame and driveline, plus front clip and trim. So about a week to build the car. Look for an ordinal date on the CFD that is within or just before that time range. I don't know what your time date code is but you can check the 1971 Ordinal numbering here. (it should be fairly close to what I think you're looking for)
One of the numbers will likely be from the mold the pump came from, the 3 digit will be the actual date the pump was cast.
1320dragmonza
Tech Editor's Desk
Aug 17, 2013 04:44 PM
