water pump with 2 outlets
Old April 18th, 2013, 01:52 PM
76 Delta 88 Royale
slayed's Avatar
Im doing my first repair on a 76 delta 88 royale. The original water pump I took off has 1 outlet.
I first ordered a pump from Advance Auto Parts and it came with 2 outlets so I returned it because they had one listed with just one outlet. I had to wait 3 days for it to arrive from the manufacturer. When it arrived it also had 2 outlets, but came with a cap and a clamp.
Should I just install this pump? Is the cap and clamp sufficient or will it mess up the flow of coolant? Thanks ahead of time for any help!
slayed is offline
Old April 18th, 2013, 02:13 PM
When you say "two outlets", I assume you are referring to the bypass outlets on the top of the pump. One is obviously used for the T-stat neck bypass. The other is usually for the heater hose, but I'm guessing that on your car the heater hose goes to the radiator instead. It is common and perfectly acceptable to cap the unused outlet. Just be warned that most of the caps provided with water pumps are cheap molded rubber with no internal fiber reinforcement. I've seen them dry out and crack after a relatively short period of time (like a year or so) and start leaking. If you use the cap, inspect it regularly for cracking and potential leaks.
joe_padavano is offline
Old April 18th, 2013, 02:23 PM
76 Delta 88 Royale
slayed's Avatar
Thank you. I was unsure if this was an acceptable fix or just the manufacture being lazy. It does have the cheap rubber cap. What other method/material would you suggest to cap it off with?
slayed is offline
Old April 18th, 2013, 03:57 PM
Rocket331's Avatar
I've used a short section of hose with a big bolt clamped in it. It's not pretty, but it's effective.
Rocket331 is offline
Old April 18th, 2013, 04:36 PM
It pains me to admit I've done this too. I recently got a set of the caps from NAPA. Still no reinforcing cords, but the do seem to be better made than the Chinesium ones that come with the pumps.
Old April 18th, 2013, 05:29 PM
76 Delta 88 Royale
slayed's Avatar
My father is being kind of skeptical on using the cap and clamp with 2 outlets. I found one that can be here in 4 days with just one outlet, so it looks like Ill be waiting until later this week to do any more work. Im going to go over all the rust with some steel wool while I have it all apart to hold me over until I get the proper part. Thanks guys!
slayed is offline
Old April 18th, 2013, 05:33 PM
Rocket331's Avatar
Better yet!
Nor Cal Andy
March 29th, 2012 07:27 PM
72Ctlss
June 23rd, 2009 03:12 PM
greener_dude
February 18th, 2007 08:14 PM
SMOKEYMTNKUSTOMS
June 21st, 2006 04:42 AM
SMOKEYMTNKUSTOMS
February 21st, 2006 11:16 AM
Quick Reply: water pump with 2 outlets
