Washer pump hose hook up
Old Jun 18, 2012 | 04:44 PM
Custom68's Avatar
Hi guys does anyone have a diagram of the hose hook up for the washer pump on a 71 cutlass? Also my reverse lights don't work. I put in new bulbs and replaced the brake switch, still nothing. Just wondering if it could be the neutral safety switch? Don't know what else it could be.
Old Jun 18, 2012 | 04:49 PM
Middle hose goes to tank, outside hoses go to nozzles.
The brake light switch has noting to do with the back-up lights.
The neutral safety switch seems like a likely culprit - just unplug the back-up light plug from the switch and short across it with a paper clip. If the lights light, then the problem is the switch.
Old Jun 18, 2012 | 05:08 PM
Custom68's Avatar
Hey thanks a lot MDchanic. I'm going to try that and see if the lights work. As for the washer pump thanks for that one too. Will let you know how the lights work out.
Apr 23, 2013 06:16 PM
costpenn
Jan 12, 2013 10:13 PM
Custom68
Jun 18, 2012 11:41 AM
projectheaven
Jan 8, 2012 09:17 AM
64Olds98
Nov 17, 2010 05:26 AM
