Washer pump hose hook up
Hi guys does anyone have a diagram of the hose hook up for the washer pump on a 71 cutlass? Also my reverse lights don't work. I put in new bulbs and replaced the brake switch, still nothing. Just wondering if it could be the neutral safety switch? Don't know what else it could be.
Middle hose goes to tank, outside hoses go to nozzles.
The brake light switch has noting to do with the back-up lights.
The neutral safety switch seems like a likely culprit - just unplug the back-up light plug from the switch and short across it with a paper clip. If the lights light, then the problem is the switch.
