warm air from vents set on cool
Old Jul 22, 2012 | 03:42 PM
69'442's Avatar
Any ideas why warm air would come out when set on cool vent. It does get hotter when set to warm but it feels a lot warmer than outside air when set on cool vent. It is a 70 442 with a/c. A/C not charged. Just wanted to get outside vent air not heated.
Old Sep 23, 2012 | 12:33 PM
69'442's Avatar
What do you think?
Old Sep 23, 2012 | 12:43 PM
4424me's Avatar
perhaps the blend door isnt closing or sealing fully?
Old Sep 23, 2012 | 12:47 PM
On a warm day, if you are not really moving, air through the firewall or heater vents will be warmer than outside air.
On a cool day, it will be slightly warmer, but you won't notice.
In A/C equipped cars, the A/C system should activate a hot water valve when set to "Max Cool" or when the Temp lever is all the way at the cold end, which will close off the water supply to the heater core, and allow the vent air to be a bit cooler.
Unless you start off with the hot water valve closed before the engine warms up, you will not notice any cooling effect in closing it later on.
Promethean
Apr 18, 2013 03:52 PM
69'442
15
Aug 2, 2012 06:55 PM
erudek
Oct 4, 2010 06:25 PM
rustyold66
Aug 7, 2008 07:52 PM
beanship
Bravada
Jul 10, 2007 12:36 PM
