Wall of shame
Old Dec 3, 2017 | 09:07 AM
  #321
oldstata's Avatar
Justin
Your muffler brake pads are worn out , we can do that for a low price
Old Dec 3, 2017 | 09:10 AM
  #322
At least they retained the rubber mounting...
Old Dec 3, 2017 | 09:31 AM
  #323
scottv442's Avatar
Maintained
Originally Posted by oldstata
Just did brakes and has horrible grinding noise
bin there
Old Dec 3, 2017 | 04:23 PM
  #324
JohnnyBs68S's Avatar
Might be lame compared to most of the pictures / stories on this thread, but is true.
Back in '97, I purchased a low-mile '94 Z28 Vert, great shape, but got such a good deal I had enough left over to buy a winter beater to save the wear and tear on the Z. Picked up a '84 Nissan King-Cab pickup for $800, rusted to beat all hell. The lower fenders on the bed had rusted off (from a distance, you could see light between the frame and bottom of the bed.......I know you've seen them like that) and it was held to the frame w/ one bolt. That was the first thing I repaired, followed by making sure all fluids were OK and no major leaks to get me through the winter. All winter long, it had a severe back fire, so harsh sometimes that it would buck and chirp the tires even in 2nd gear! Following spring I tackled that w/ a full tune-up. Discovered the cause of the back fire, it was the distributor cap that was loose because it was being held on w/ only one screw that wasn't even the correct fastener. I'm lucky I didn't get stranded. Ended up getting 2 useful years out of that truck, one time carrying 2600 lbs of gravel for my g/f's driveway (someone had bolted on "helper springs" that kept it from bottoming out on the rear axle), and multiple loads of hay for her horse. One time had two ~6' x 5' rolls strapped into the bed, another with the help of some plywood sides I built, had bales stacked so high that it created so much aero-drag I couldn't get it to go over 50 MPH. Ended up trading it in for more that twice what I paid for it. Definitely got my $800 worth out of that beater.
Old Dec 11, 2017 | 10:02 AM
  #325
oldstata's Avatar
Justin
Found this on a fb group hopefully it’s a fake hahaha
Old Dec 14, 2017 | 09:33 AM
  #326
TripDeuces's Avatar
Saw this today on FB.
Old Dec 17, 2017 | 07:42 AM
  #327
zeeke's Avatar
Does that qualify as a tubular lower control arm?
Old Dec 17, 2017 | 06:01 PM
  #328
If he welded it right, it may be stronger than the original.
Old Dec 18, 2017 | 07:09 PM
  #329
oldstata's Avatar
Justin
with re bar ? Not sure about that lol
Old Dec 18, 2017 | 07:18 PM
  #330
oldstata's Avatar
Justin
Yes we caught fire
Old Dec 19, 2017 | 05:12 AM
  #331
gs72's Avatar
72Cutlass S
I have never seen one of these break. It's out of an Eaton 18 speed trans from a big rig. This part came out of a hydro-vac truck that had the vacuum blower lock up during operation. It blew up the transfer case and snapped the input shaft all at the same time. They run these units in 18th gear at 1200 rpm. That's probably around 2000 lbs. ft of torque when it all let go.IMG_0405.JPG
Old Dec 28, 2017 | 07:15 PM
  #332
oldstata's Avatar
Justin
Old Dec 28, 2017 | 07:28 PM
  #333
Gary M's Avatar
10 more miles and those will fit. Gives new meaning to " break in period!"
Old Dec 28, 2017 | 09:13 PM
  #334
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Thats what that rub block is there for...one size fits all just needs to "lap in" a lil...LMAO. Driver never heard it either...oy.
Old Dec 29, 2017 | 03:25 AM
  #335
Gary M's Avatar
Seems like it would sound like a bicycle with playing cards flapping against the spokes as you roll along!
Old Feb 23, 2018 | 03:45 PM
  #336
oldstata's Avatar
Justin
Customer exhaust hanger welded to the rear toe cam bolt
Old Mar 7, 2018 | 05:26 PM
  #337
zeeke's Avatar
This came from a G-body post another member found.
Old Mar 7, 2018 | 06:12 PM
  #338
Gary M's Avatar
That will buff out
That looks like shear determination at its worst.
Old Mar 9, 2018 | 12:12 PM
  #339
golden rocket's Avatar
golden rocket
About 1977 I was working in a small, independent shop. Elderly lady came in with a 1961 Ford sedan, 6 cylinder 3 speed. Said her car was running awful, must need another motor or something. I said we should run it up and down the service drive a couple of times, so I could better understand exactly what she needed. I drove it, with no problem, back and forth. And she told me I was driving it wrong. She shows me how she drives it, and it runs like a dog. I'm scratching my head at the change, so ask her to show me how she starts the car to drive it. "Well Ford put this nice purse hanger, right here for me" She had pulled the manual choke out enough for her purse to hang on.
Old Mar 15, 2018 | 05:51 AM
  #340
oldstata's Avatar
Justin
14 mile wrx 2018
Making horrible sounds and I am just learning how to drive a manual .........
Old Mar 15, 2018 | 06:07 AM
  #341
Funkwagon455's Avatar
Fourteen miles!!
Old Mar 15, 2018 | 07:09 AM
  #342
cjsdad's Avatar
What gear is that and how can it get that damaged that quickly?
Old Mar 15, 2018 | 08:15 AM
  #343
Indy_68_S's Avatar
Ha. No need to use that third pedal. It's just for decoration.
Old Mar 15, 2018 | 10:33 AM
  #344
oldstata's Avatar
Justin
1st gear and it’s on the reverse assembly lol
his actual complaint was” just bought this and I don’t know how to drive it and it’s making a horrible sound luckily I am not the tech working on this lol we have to reach 91% before a full replacement can be made and it’s at 87 hahah
Old Mar 15, 2018 | 11:50 AM
  #345
RetroRanger's Avatar
72 Olds CS
Ouch return it NPF should reach 91% by the end of the parking lot
Old Mar 15, 2018 | 01:06 PM
  #346
70-442-W30's Avatar
344879M363895
From my B&S-powered Snapper riding mower:
Old Mar 15, 2018 | 04:35 PM
  #347
TripDeuces's Avatar
That ought to do it
Old Mar 16, 2018 | 01:54 PM
  #348
kenmosher's Avatar
Too much boost ... not enough fuel ...
Back in about 1990 ... we were at a Friday Night No Prep night ... I had slicks on my Grand National and some high school kid ahead of me tracked water in his freakin' snow tires on the track. Launched the car and it actually hooked well (low 1.60 short time) and then about 100-150 feet out it spun so fast I couldn't catch it. Heard it pop and just figured it was the hoses on the intercooler (they'd pop off on overboost a lot of times). Little did I know ... Sort of peddled it and coasted to the finish line to be met by the firetruck!
When the piston melted, crankcase pressure shot up and it puked oil out of the valve cover breathers. The oil ran down the hot downpipe and where it dripped off under the car it caught fire. People told me it looked like a jet under the car!
VERY fortunately as I bailed out ... a little squirt of water put it out and when I got it home and tore it down I found this piston. There was a scorch mark on the downpipe and it was greasy, but that all cleaned up with some steel wool. Didn't even mark the underhood paint! Ended up rebuilding the engine using a new block since that piston had lightly scored the original block in that hole (I still have that block). Funny thing was, really no damage anywhere else in the motor! Looked brand new and never did find that piece of missing ring!
Car was running mid/high 11s back then and still "the family car".
Old Apr 18, 2018 | 12:14 PM
  #349
oldstata's Avatar
Justin
I am sure there are better ways !!!!!
Quote from the tech that found it “Fishing accidents are a viable alternative to divorce. THIS will get you caught, buddy.”
My husband replaced my brake lines a week ago 😮😮😮
Old Apr 18, 2018 | 03:28 PM
  #350
zeeke's Avatar
Wow & wow!
Old Apr 18, 2018 | 07:05 PM
  #351
My wife brought the car in?!?
Old Apr 24, 2018 | 09:40 AM
  #352
TripDeuces's Avatar
http://machineusa.org/2018/04/23/bes...tion-jan-2018/
Some of these are great.
Old Apr 24, 2018 | 11:09 AM
  #353
Hilarious
Old Apr 27, 2018 | 11:27 AM
  #354
Weezer's Avatar
Jeff
Saw this on a FB ad for a '76 Cutlass, "some metal was replaced on body can see in pic". At least it's not plywood, I guess...
Old May 11, 2018 | 04:42 AM
  #355
zeeke's Avatar
Got this dosey off facebook.
Old May 11, 2018 | 05:45 AM
  #356
oldstata's Avatar
Justin
Found this one on fb too lol
Old May 11, 2018 | 05:56 AM
  #357
The old 1 million amp fuse.
That zip tie trick WOULD get you home, provided it held air.
Old Jun 24, 2018 | 02:34 AM
  #358
zeeke's Avatar
Here we go again, a set of restricted headers for the low price of $85. Add says never installed and they fit Chevy, Buick, Oldsmobile, Pontiac. I guess they are universal and pre-crimped. Never installed??? How did the hot spots get there a torch? I've heard this theory before... "When all else fails bash it with a hammer."
Old Aug 18, 2018 | 02:47 PM
  #359
oldstata's Avatar
Justin
Found a video on fb and had to screen shot....
Old Aug 18, 2018 | 03:02 PM
  #360
costpenn's Avatar
From the front axle of a 79 Ford F-250 4WD I'm doing a resto on. It took me a minute to figure out what had happened
