W27 Cover Real?
Old Jan 2, 2017 | 04:25 PM
Magna86's Avatar
W27 Cover Real?
Ok guys what are your thoughts on this cover? I believe it to be real as I have never a repro with all the fins there. If it is real what's the value on a real cover? You don't see real covers alone very much just the rears. This cover has been on the car for over 15yrs. Thanks for any input.
Old Jan 2, 2017 | 05:26 PM
^^^this
Here's just one vendor (Fusick) that sells them. Note: all fins are there
Looks like this when added to the cleaned up axle and differential:
Old Jan 2, 2017 | 05:33 PM
Magna86's Avatar
They all have the fins on the outside its the inside where the repops are missing them. That's why I'm curious on this one.
Old Jan 2, 2017 | 06:21 PM
Ctls442's Avatar
What are the physical differences between a real W-27 cover and a repro? Does anyone have pictures of the two side by side?
Old Jan 8, 2017 | 02:35 PM
classicmuscle442's Avatar
Would like to know also.
Old Jan 8, 2017 | 07:17 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
The cover pictured by Magna86 is a reproduction
Old Jan 8, 2017 | 07:33 PM
original
compare the edges of the w 27 lettering and the edges of the hex holes
Old Jan 10, 2017 | 08:01 AM
Magna86's Avatar
Since repro it's now cleaned up and finished how I wanted to go on my rear. 😁
Old Jan 10, 2017 | 09:26 AM
VC455's Avatar
Barely Registered
Originally Posted by w-30dreamin
original
Thanks Dreamin.
A picture always helps show the differences. Comparing the two, the original mold were made by die-makers, the repro mold was made by children who couldn't draw a regular hexagon, much less form letters consistently.
When I looked at the one I've had for years, I realized it was made by the same children who made the one pictured.
Old Jan 10, 2017 | 12:04 PM
70Post's Avatar
Nobody has a pic of the backside of a repro? (other than the cover Magna shows)
Old Jan 10, 2017 | 12:37 PM
Bernhard's Avatar
Your cover is very close to original in appearance I would not be in a rush to sell it with out further proof that it is not original.
I would like a side by side comparison with a original cover before I sold it for less than it might be worth unless you need the $ now.
Old Jan 10, 2017 | 12:56 PM
Stefano's Avatar
I agree with Bernhard.
Right now the main defining difference that I can see is that the shallow relief above the "W" droops down on the left side more than the right side, which originals do not. At least the ones I have seen.
The repos today are very noticeable and less crisp, but the one you have seems close to an original style.
Why did you paint it with "cast blast" dark aluminum color?
Old Jan 10, 2017 | 12:59 PM
Here's a pic of the inside of a reproduction in a thread over at supercars reproduction.
http://www.yenko.net/ubbthreads/ubbt...-rear-axle-cov
Old Jan 10, 2017 | 01:05 PM
Take a good look at this original cover
Old Jan 10, 2017 | 01:13 PM
your welcome
Originally Posted by VC455
Thanks Dreamin.
Old Jan 10, 2017 | 03:49 PM
Magna86's Avatar
I painted it the dark cast aluminum because I like the look better than the bright aluminum. It's also helps hide any imperfections and dirt once on the road.
Old Jan 10, 2017 | 08:32 PM
Bernhard's Avatar
I agree this is a high quality copy or original.
Nothing in the video or super cars thread has changed my opinion on the cover.
X2 two on painting the cover, soda blast and clear coat would be my choice for the cover restoration.
Old Jan 10, 2017 | 08:51 PM
70Post's Avatar
I'm almost thinking that the "defect"/droop on the L side of the depression area above the "W27" is at least one solid indicator of a repop (haven't seen that "feature" on any originals so far). It's as if they left a glob of metal in the mold in that position on the repro mold/tooling.
Old Jan 10, 2017 | 09:43 PM
Ctls442's Avatar
your welcome
Thanks w-30dreamin; the difference is clearly discernible between your original cover and the repro with the defect/droop. Does anyone have a cover that they know to be a repro without the defect/droop? I'm trying to educate myself on the telltale signs of a repro cover before possibly buying one from someone who claims to have an original.
Old Jan 11, 2017 | 04:55 AM
Your welcome but just to clear things up,these are not my covers.
I have taken pics from the internet that are available to anyone.
I learned this from info that has been posted on this page before.I have been studying and reading for many years.
The info is out there if you pay attention and research.
I have always had an eye for detail so spotting the differences is easy for me. As I can see,not so easy for others.
Old Jan 11, 2017 | 11:46 AM
Bernhard's Avatar
If that is the case then I would agree that it is a reproduction.
The issue I have with absolutes is that how do you know how many tooling's the factory had or if they were ever repaired?
I have come across some very clean block, head castings and some very poor castings.
Old Jan 11, 2017 | 06:19 PM
jensenracing77's Avatar
I have avoided this thread but can't take it any more, lol. To me this is obviously a repop. This seams to come up often.
Old Jan 11, 2017 | 07:15 PM
Good eye Eric,thanks for chiming in with your valued opinion. Over time I have learned much from reading your posts. thank you
Old Jan 11, 2017 | 10:11 PM
70Post's Avatar
Bernhard - I'm not trying to state "absolutes". Instead WONDERING if it could be the "decisive" factor but as you state.....the repro mold could have been "fixed" or who knows....maybe there are some ORIGINALS out there with this "defect" and one of those was used to make the repro mold/tooling. And then the original factory fixed their mold.
No kidding on block and head castings....some with massive chunks hanging off of certain areas.
Old Jan 12, 2017 | 09:48 AM
Bernhard's Avatar
Compared to other reproductions were would you rate this W 27 cover?
Good
Average
Bad
Old Jan 12, 2017 | 11:15 AM
Good
Average
Bad
To be honest, None of the repops are very good when compared to the originals but 95% of people would not know. The thing is, The originals are so rare that it is not a common thing for people to see and be use to a correct one. To top that off, most of the real covers that get posted are used and that makes it even harder for some people to tell them apart from pictures. I am not a "professional" W-27 guy but have owned a couple of them and examined them closely.
Old Jan 12, 2017 | 11:37 AM
The cover that the OP posted is either The Parts Place or Super Cars Unlimited, they have the same cover to the best I know. I love Fusick but I have to admit, there W-27 cover sucks really bad, at least the one I seen of theirs about 5 years ago did.
Old Jan 12, 2017 | 02:48 PM
I would love that NOS cover! This is the last one I had after cleaning it up.
Old Jan 12, 2017 | 02:56 PM
joesw31's Avatar
Eric, that is a nice cover!
Old Jan 12, 2017 | 03:12 PM
Ctls442's Avatar
After seeing these two pictures, the differences between original and repro are plain as day; thank you for posting. Seeing the beauty of the original cover is motivating me to clean up the W-27 I have had in storage since 1988. Unfortunately, the aluminum has darkened over the years (I believe due to moisture).
Old Jan 12, 2017 | 03:30 PM
  #31
After seeing these two pictures, the differences between original and repro are plain as day. Seeing the beauty of the original cover is motivating me to clean up the W-27 I have had in storage since 1988. Unfortunately, the aluminum has darkened over the years (I believe due to moisture).
Just be careful how you clean it up. Joe would know better than I would but the aluminum on the W-27 is a little darker than what you would think.
Old Jan 12, 2017 | 03:35 PM
  #32
Ctls442's Avatar
This Spring I will bring it outside for some close-up pictures, and will ask for recommendations on clean-up/restoration.
Old Jan 12, 2017 | 07:47 PM
  #33
Bernhard's Avatar
Thanks for posting the picture of the nos w27 cover.it is easy to spot the re-pop
The Nos cover has a milled face the hexagon's are crisp and there is no defect in the top left corner.
It is easy to spot once you have seen a clean cover v re-pop.
Old Jan 16, 2017 | 11:42 AM
  #34
oldspackrat's Avatar
IIrc, wasn't there a 10 bolt aluminum W27 COVER only available across the parts counter in '71-'72? I acquired this a handful of years ago & was wondering whether it was real or not? It has a couple chips on it & has a jack cradle mark on the bottom like it had been on the car a long time. It has been sandblasted? The face is not milled & there is no part number on it. I was told it was a dealer purchase but don't know for sure. Any help is appreciated.
Old Jan 16, 2017 | 11:55 AM
  #35
I don't know what a real 10 bold cover looks like. I know W-27 was an available option in 71 but it was only the cover. When you come over bring it with you. There is something I would like to see on it.
Old Jan 16, 2017 | 12:08 PM
  #36
Bernhard's Avatar
Cool 10 bolt cover I like the cast bolts.
Do you know if anyone ever produced one for the 12 bolt Chevy?
Old Jan 16, 2017 | 12:20 PM
  #37
Scott,
your cover looks exactly like the repop I bought from Parts Place. Looks like you took it through the sandblaster?
Old Jan 16, 2017 | 12:23 PM
  #38
Someone does. I seen one listed for sale before, just can't remember who it was.
Old Jan 16, 2017 | 12:26 PM
  #39
Allan,
In your picture from 1-2-17 I thought they looked similar. I don't remember if I blasted this or if it was like this when I got it?
Old Jan 16, 2017 | 01:21 PM
  #40
Allan,
I said that based on the texture of the cover. Mine looks bright and almost polished out of the packing box. You are correct that the W27 cover was available as a bolt on part from the dealers. It's more than just a look, the extra fins provide extra cooling and the capacity of the differential increases by about ?? 500 ml of fluid. Don't know the exact amount but it's significantly more than stock 71/72.
