venting the gas tank
Old Apr 17, 2013 | 03:51 AM
1954Bob's Avatar
Question venting the gas tank
Anyone know anything about venting the gas tank on a 1967 442. The car when we broke it down for resto had 2 lines coming off the tank and one had a hose with a old spark plug shoved in it. Anyone know the correct way to vent it and parts needed to do that job.
Thank you , Bob
Old Apr 17, 2013 | 06:36 AM
There are a couple of kits that work, basically 2 rubber lines and a plastic filter stufffed with cotton. It clamps in behind the bumper above the license plate.
Just scroll down until you see it:
http://www.inlinetube.com/New%20Prod...Oldsmobile.htm
Old Apr 17, 2013 | 06:59 PM
2blu442's Avatar
That will work well, but I believe the factory setup was a little different in 1967. What I've seen is a chuck of cotton like filter stuffed into the end of the large hose and a plastic plug with a small hole in the center pushed into the small hose.
I wasn't able to get the link to open, but I believe what Oldcutlass is describing was used in 1968-72 and would probably work better than the factory 1967 parts.
John
Old Apr 17, 2013 | 07:17 PM
I looped my 2 lines together and don't run a vent. I get a minor pressure build not enough to affect anything on a really warm day.
19sixty5
Non-Olds Engines
Feb 10, 2014 03:35 PM
ah64pilot
Apr 9, 2012 02:55 PM
Texas442
Jan 30, 2012 05:36 PM
one4theroad
Oct 10, 2009 01:54 PM
glord
Jul 21, 2009 11:23 PM
