value of G body 4 speed set up?
Old Oct 31, 2009 | 08:01 AM
2X72's Avatar
Hey Guys, just wondering what the value of an original 4 speed set up be worth for a G body? Have bell housing, clutch fork, z bar & rods, pedals, frame bracket and metal shifter hump for the floor. I think I have the reverse lock out linkage but I need to verify it is correct. All in good shape but needs to be cleaned and painted. Any input would be great.
Old Oct 31, 2009 | 08:21 AM
OldsMotion's Avatar
OldsMotion
Impossible to tell. I do not know of ANY G bodies that came with a 4 speed.... except possible an El-Camino.
Now if you are talking about the 1978-80 A-body stuff (that came behind the super awesome 260 in the Cutlass for example) you could probably get a few hundred for it.
Old Oct 31, 2009 | 09:11 AM
rocketraider's Avatar
Oldsdruid
The trouble with these is that they are ALL chevy bolt pattern bell housings. 4-speed was factory available only behind the 305 and then only thru 1980.
I've seen more Malibu/ElCamino versions than others, but there were more than a few Cutlass 4-speeds built from 78-80, and all with 305 Chevy engines. 260s and Busix came with 5-speeds- which weren't anything to write home about fun-wise either. Gas mileage with overdrive 5th was their raison d'etre.
But there's nothing in the rule book that says you can't put a BOP bellhousing on the back of an Olds engine that has a Z-bar boss and play that way. Pretty sure a Muncie will bolt to it.
Old Oct 31, 2009 | 09:54 AM
2blu442's Avatar
Many years ago I pulled parts from a 1979 Pontiac Grand Prix that had a three speed on the floor. I didn't get the transmission or bellhousing before they crushed it, but I thought it was a 6 cylinder engine. If my memory is right, would that have had a BOP bell housing that would fit the V8's? John
Old Oct 31, 2009 | 10:53 AM
Oldsdruid
That car probably had a Buick 3.8 V6, so it would have had a BOP pattern bell.
Old Feb 19, 2010 | 01:58 PM
1988MCLS's Avatar
Do you still have this setup? I sent you a pm..Inerested in it all,Thanks,Erick
Old Feb 24, 2010 | 04:01 PM
1988MCLS's Avatar
Are the parts still available????I sent 2 pm's with no reply????
Old Feb 24, 2010 | 04:04 PM
1988MCLS's Avatar
I did find a factory 231 3 speed setup out of a 78 lemans...But i need 2 setups for 2 cars i am changing over..Yes the 231 bellhousing will fit Buick Olds And Pontiac...has starter provision on both sides...When i get it, I will not be using the 231 bellhousing...I am going 350 in both cars.
ihengineer76
Jul 23, 2024 04:15 AM
spb350
Aug 14, 2013 06:29 PM
Napoleon Solo
Apr 24, 2013 11:02 AM
taa442
Jun 17, 2012 03:25 PM
DennisG.
Jun 17, 2010 12:24 PM
