Vacuum on a stock 68' 442 rodchester carb
On my stock 68'442 i'm looking to find out what the normal vac. should be at idle (700 RPM) from the front port (Rodchester) that feeds the Ported Vacuum Switch?
This Ported Vacuum Switch uses vac from the carb when it's cold and then switches to the manifold vac when it's hot? (FEEDING the DIST.)
It just seems that I don't have enough vac. when it's cold. Thanks for anyones help.
Dan
Dan
Dan
Dan
odddoylerules
24
Jan 22, 2014 06:35 AM
