Vacuum reservoir
Old Jan 24, 2018 | 05:17 PM
dennis_30281's Avatar
Vacuum reservoir
Is the vacuum cannister located on the left inner fender well on my 62 Starfire necessary any more since I am installing front disc brakes with power booster?
Dennis
Old Jan 24, 2018 | 07:11 PM
Charlie Jones's Avatar
Phantom Phixer
If you are using a more " modern " power booster , you probably won't need the vacuum tank .
But , it wouldn't hurt to keep it either . It gives you an extra "power" application , after losing vacuum .
Old Jan 24, 2018 | 08:36 PM
oldspackrat's Avatar
If the car has AC or power trunk you need to keep it. On AC cars it helps move the various doors to control air flow. If you have power trunk it supplies enough vacuum to pop the trunk at least one more time when you shut the car off.
Old Jan 25, 2018 | 05:46 AM
The reservoir is in such a tight place I think I'll go ahead and install it. I'm using a Vintage air Gen II ac but I plan on retaining the fresh air vent doors and I'll need the extra vacuum for them. By the way, I put a vacuum pump on the old diaphrams and they still work!
Dennis
jensenracing77
Jan 17, 2017 03:44 AM
77ricbaez
Oct 15, 2016 04:23 AM
jensenracing77
Nov 23, 2014 01:07 PM
george landis
Nov 22, 2014 06:22 PM
oldroyale
May 27, 2011 10:49 PM
