under hood light question
i'm looking for some help on the under hood light, how is the wire connected to the actual light socket...is it pinched in or soldered or what? it has to slide back and forth freely but looking at i'm not sure how it was attached
picture enclosed
thanks
picture enclosed
thanks
Far as I know, it was crimped into the central post of the light socket, just like all of the other bayonet-base sockets.
You may need to solder it to get it to work, though.
Don't forget the spring!
thanks eric i will see if i can crimp it dont think i can solder it the sleeve is steel, and looking at it it is going to be hard to crimp because the small sliding sleeve is inside the larger sleeve
another pic....it almost looks like it would have to be taken apart but the socket looks machine crimped into the light housing
I agree with the general idea that "you can't get there from here."
Those parts were assembled by machine in a certain order, and there is a good chance that you couldn't do it again the same way.
Probably a much better bet to buy one from Scott.
I show how that light goes together in my restoration thread. It's very easy once you see how it was done.
Brian
https://classicoldsmobile.com/forums...n-project.html
Brian
https://classicoldsmobile.com/forums...tml#post446951
Excellent writeup on it - I did not know they would come apart so easily!
Brian
Brian
Brian
heritageadam
November 29th, 2012 09:02 PM
