Trying to identify distributor
Hey guys I have been wanting to replace my points distributor d a guy i know had a non points distibutor lying around and he gave it to me. I'm trying to figure out what exactly i have here. It does not have the cap on it. There are markings on the bottom that read
REMFG
IV D10
I can take pictures if needed. I hope you guys can help me out. Thanks
REMFG
IV D10
Should be able to install it. set it for number one. get your HEI cap and rotor and plug wire set. Just tell the parts house you have a '75 455 for the parts you need. Pick up a 12 volt source that is key on only. make sure the 12 volt source does NOT come on when the key is on acc position. For the most part it should work. If you have no history of the dist. you may want a new module to install.
Set your timing for 10*12* or 15* what ever you think is good for you. I have found OLDS likes a little more timing above the factory spec. Go with what you feel is good.
Gene
Gene
2blu442
November 19th, 2013 02:45 PM
BILL DEMMER
July 5th, 2013 09:19 PM
