Tranny making LOUD noises
Old Sep 29, 2013 | 10:44 AM
71cutlass442's Avatar
I took my car out last night for a quick spin 10mins and by the time I pulled into my driveway I noticed my car making a loud clanking noise. I really don't know how to describe this noise other than it sounds like a socket is bouncing around in my torque converter. When I rev the engine it goes away but as soon as I let off the gas..... There's that clanking noise!! What in the world is that??
Old Sep 29, 2013 | 11:27 AM
Dshelvy's Avatar
My first guess would be to check the torque converter bolts on your flywheel
Old Sep 29, 2013 | 12:53 PM
Agreed - loose TC or crankshaft bolts, though there are plenty of far less benign possibilities.
Old Sep 29, 2013 | 04:24 PM
Sampson's Avatar
Does it do it with the car in neutral/park? If yes then it is from the torque converter forward. If no it could be anything from the trans back. Good luck.
Old Sep 29, 2013 | 06:31 PM
Hey Sampson, it does it from the moment I start the car. In park, neutral, and in drive, the noise is there. If I rev the engine the noise goes away.
Old Sep 30, 2013 | 05:14 AM
tru-blue 442's Avatar
Old School Olds
Cracked flywheel, or loose bolts
as Eric suggested.
Old Sep 30, 2013 | 04:18 PM
Damn once again the car didn't win!! For all those that lent a hand thanks ...... The TC bolts were loose and causing my flywheel to spin against my starter housing. So glad it was that simple.
Old Sep 30, 2013 | 04:20 PM
x2
Old Sep 30, 2013 | 04:50 PM
Dshelvy's Avatar
Did you do a trans or motor swap recently?
Old Sep 30, 2013 | 08:08 PM
Yea the swap was about a year ago
Old Oct 1, 2013 | 03:37 AM
Make 'em tighter next time. ... And there's nothing wrong with a little blue Locktite.
Old Oct 1, 2013 | 06:39 AM
brownbomber77's Avatar
BLUE locktite??? Ew...never used the stuff, always go full throttle with the red locktite...haha Especially on parts I can't get to or need to stay for extended periods of time.
Old Oct 1, 2013 | 06:44 AM
Red needs heat to release, blue doesn't.
Both hold about the same.
Your choice.
Old Oct 1, 2013 | 08:36 AM
jensenracing77's Avatar
Sorry, The title of you thread grosses me out.
Glad you found the problem though
Old Oct 1, 2013 | 08:58 AM
Eh. It's usually all for show anyway.
Unless it's because you didn't pay 'em...
jkoester122
Aug 30, 2011 05:04 PM
cluelesscutlass
Aug 13, 2011 06:55 AM
ELECMAN
Aug 17, 2010 07:13 PM
WasteOfMind00
Apr 18, 2007 08:10 AM
