trailering question
Old Jul 25, 2011 | 04:25 PM
GTI_Guru's Avatar
Certifiable car addict...
trailering question
Considering trailering a full-sized 1965 Oldsmobile starfire about 8 hours.
I have trailered a 66, but that was a long time ago (20+ years), and I don't have access to the same trailer I used back then, nor do I remember the exact size of it.
What's the minimum size trailer deck I need to be safe? Dual axle and rated for at least 5,000lb would be my minimum carrying capacity to be comfortable, but the deck size has me concerned, as this is one big car.
I have access to a few trailers from friends, but not sure if they are up to tackling that size of vehicle.
Just looking for some input before I make the trip so I don't end up with one that's too small.
Thanks!
-Jeff
Old Jul 25, 2011 | 04:48 PM
U-Haul's prices aren't bad on those trailers, if worse comes to worst.
I wouldn't classify the trailer by size, though, I'd classify it by capacity.
Anything that is long enough to handle the wheelbase (which is what, about 120"?) should be fine.
Old Jul 25, 2011 | 05:13 PM
Oldsmaniac's Avatar
The great thing about Uhaul trailers is that they have surge brakes so no braking controller is needed. You can go to their site and punch in what you want to tow and with what vehicle and they will say yes or no to your rental with their 4 wheel trailers. I did a 78 Ranchero with my tow vehicle 2005 Avalanche 2 wheel drive 1500 and it worked. I also did the Avalanche with a 67 442 and it worked.
Old Jul 25, 2011 | 05:27 PM
defiant1's Avatar
Below is a picture of my car on a 20' trailer. I trailered over 500 miles with my 99 Suburban 1/2 ton. I did use a weight distribution hitch, which improved the handling and trailering capability tremendously.
d1
Old Jul 25, 2011 | 07:05 PM
GTI_Guru's Avatar
d1
I've done that with u-haul already, and when you punch in a 65-66 full-size olds (delta/dynamic/delmont 88, starfire, toronado. I tried them all) it comes back with no available option.
Thankfully, I just scored the loan of a 3-axle, pintle/reese hitch trailer that will haul a backhoe with no problem. New tires, No side rails to stick up in the way, trailer brakes, and 6 BIG ratchet straps. I'm all set to go.
I've hauled a LOT of cars over the years, but never one this big for this distance, so I was trying to cover all my bases.
Thanks for the responses! Much appreciated!
-Jeff
p.s. pics forthcoming when I get her home.
Old Jul 25, 2011 | 07:50 PM
Cool!
I find that if you can borrow an approved tow vehicle for an hour and let U-Haul hook up to that, then switch to your own around the corner, it all works out fine .
yeahbuddy
Dec 19, 2011 08:40 PM
defiant1
Mar 8, 2010 05:40 PM
Dobergup
Jun 22, 2006 10:01 PM
