Totally pointless but I'm curious
I don't have a definite answer for you, but during the 1980's i had two unmolested, original-owner 1970 Cutlasses, an 'S' and a Supreme. The 'S' was a column-shift car and had the blue high beam indicator; the Supreme had Hurst dual gate and the indicator was red, so at the time i thought it had to do with column vs. console shift. Others will certainly chime in.
My 70 is red, funny I was just wondering about that too. I thought my 70 column shift was red and my 70 Wildcat was red.
remember the joke about the high beams when the switch started to get combined with the turn signal stalk.......
Why did the Texan get his foot caught in the steering wheel at night - cause he was trying to turn the high beams on!!!
of course if you are from Texas you'd say why did the "northerner"
My 70 Toronado was blue and also reflected off the windshield to remind you. I think my 66 Cutlass is blue too. ^$%#& now I'm not sure, I'll have to look now. Damn you! 65 Riviera was red.
With the Olds at least 1970 was the last year for the red high beam indicator. Blue appeared in 71. If you pull your speedo out and look at the date on the housing I'd lay odds it's a 70 speedo.
Gee I thought one year would be one colour and change the next. My 71 supreme is red with a april build date(i Think) so I could have a 70 speedo also column shift.
Larry
I guess I should have known better It wouldn't be easy answer and would open a can of worms. Honey it's midnight why are you going out to the car. I forgot the colour of the high beam indicator.
Larry
Recon export models may have differed?
Seems GM has used blue for a long time for HBI. My 78 Ford uses red.
I assume the change was because that red is associated with problem indicators...
Adam
UNHLAW2016
May 15th, 2014 06:40 AM
lansing
December 19th, 2010 11:09 AM
