Tire Pressure
Old Sep 9, 2012 | 11:43 AM
Al Graaf's Avatar
Formerly "Shimmer"
Tire Pressure
What tire pressure do you guys recommend? Also, where's the best place to buy replacement wheels 71 442-mine seem to be out of balance and out of round. Guesss been through hell all these years.
Old Sep 10, 2012 | 09:20 AM
Gary's 2 442-S's Avatar
Gary
Al, I got my tires from Discount Tires. they are BF Goodrich T/A ,on the back I have 275 60r 15 ,On the front I have 255 6or 15. Now I don't know what tire pressure they put in the tires.
Old Sep 10, 2012 | 09:55 AM
cutlassjoe's Avatar
I run between 34-36 psi. Anything higher the ride is too bouncy or stiff. Too low and it kind of floats a bit.
Old Sep 10, 2012 | 09:59 AM
I run 30#'s in my tires, very similar to yours.
Old Sep 10, 2012 | 10:15 AM
Mr Shifty Sidney's Avatar
Al Graff
I bought repo SSI rims through Summit. I ordered 15 X 7's with 245/60/15 BF Goodrich tires. They will mount and balance the tires. When they arrive at your house all you have to do is inflate and install. I have had mine a couple of years and am pleased with them. They do not come with center caps. I installed some GM center caps that I already had.
Don W
Old Sep 10, 2012 | 10:18 AM
rjohnson442's Avatar
Mr. Johnson
I have the 275 60r 15 also. run 35 on the street both tires.. At the track I run 22 right 24 left tire. They will still hold a bead around 17-20 psi also
Old Sep 10, 2012 | 10:25 AM
Lady72nRob71's Avatar
I run at 35psi for cars I drive. If being stored for a long time I use 40.
Used wheels is my suggestion - still plenty out there.
Old Sep 10, 2012 | 12:56 PM
Depends on whether you're going to run radials or bias plys. Radial - 32 is lots especially for a wide 225+ width. Bias - in your glove box and owners manual.
Shouldn't have much trouble finding rims for your car - there are plenty on the market. Just depends on whether you want to go with new repro or OEM used
Next!
Old Sep 11, 2012 | 07:01 PM
Al Graaf's Avatar
Formerly "Shimmer"
Hi Rob-AL Graff here-totally off the subject but didn't you install electric fan on you car? Curious what kind and if you keep the old fan on as well. Also in your vast knowledge storage is is possible for the original wheels to become out of round or sorts. Have a small vibration in the *** and eveything else has checked out. Wheels are original and was going to get replacements at JEGS or SUMMIT. What's your advice?
Thank you
AL
Old Sep 11, 2012 | 07:37 PM
Thank you
AL
Ok, I know I'm not Rob but I thought I'd share this with you. Are you so sure it's your wheels?? You can check them easy enough for out of round and in/out. Reason I question the wheels as the problem goes back to this summer with my Sonata.
I have winter and summer wheels for the car. When I took off the winter ones and put on the summers I noticed the front of the car was vibrating and shaking at certain highway speeds. Took it in for a wheel balance. The shop balanced them and put the fronts on the back and vice versa. Now on the highway the vibration was coming from the back. In I went for another balance. Then another one. Still the same - it was driving me literally nuts!
Went to a Falken dealer and explained the problem. They took the wheels off and spun them on their machine. The TIRE, not the wheel had in / out play. Guess where? On the join. Turns out the tires were defective and starting to separate.
Suggestion: What about those roller wheels you had on the car? Can you put them on and see if the vibration is still there? That would certainly isolate whether the problem was body/driveline or wheels if the vibration is gone. I bet ya a mint julep it's the tires, not the wheels.
Now I return you to the 'Dark Lord'.....
Old Sep 11, 2012 | 07:51 PM
Al Graaf's Avatar
Formerly "Shimmer"
Sounds belieable. The tires are new sold by goodyear but made in Korea.
I'm going to see Elliot tomorrow and confront him on that.
Old Sep 11, 2012 | 08:12 PM
Hi Al, no I did not install an electric fan and i am kinda against doing so for the most part.
They could become bent if you slide up against a curb or so, or maybe a broke weld or such. As for out of round like an egg shape, no.
Tires can cause all sorts of strange problems.
In the past 7 years, i have experienced more bad quality in tires than I have seen in my entire life.
My Ford tires are no-names and have turned funky shapes withing a couple years. Two developed bulges on the sidewalls just after installation, which i made them replace for free.
Caddy has michilin crap in which all the sidewalls crackled in 2 years. After 5 years the rubbers is so dry rotted that they are flaking!
My neighbors Escort has Falkens which were made in japan and they are so cracked that i would not drive across the street with it! They are 5 years old, too.
Tire quality has gone down the crapper big time.
Jap made ones seem to be even worse with 3/16" deep cracks in the sidewalls.
Old Sep 12, 2012 | 02:04 AM
jensenracing77's Avatar
i have 245 60 14s on my Rallye 350. i ran 32 in them for several years and noticed the center is not wearing as much as the outsides. now i keep them at 36-38 in them.
Old Sep 12, 2012 | 08:20 AM
Prolly from all the high speed cornering you do on them narrow windy roads?? Funny, my Sonata has 215/55/17s but the recommended pressure for my car is on 30psi front/rear. The max pressure is considerably more. I'm sure the pressure used is a combination of a) ride comfort b) tire profile c) car weight. Your Rallye 350 would never have come with 245's so experimenting with tire pressures is almost a given for each application?
foreverolds
Dec 1, 2012 07:07 PM
jdana24
Wheels and Tires
Aug 14, 2011 11:05 AM
1970conv98
Ninety-Eight
Jul 9, 2010 07:19 PM
Doug69Cutlass
Apr 6, 2009 06:54 PM
Satellitecentral
Nov 6, 2008 10:52 AM
