tire age
They say 8 years, I go 10, if I can. It really bothers me to buy new tires when mine are like new. I don't drive mime much, or long distance. But I have a trailer, and they look new, but I don't take a chance, on a trailer. I learned this the hard way. Years ago, when going to a Olds Nat in Seattle, I blew a tire, scratched the side of my car, $2500 damage, and had to buy new tire before I came home. In the long run, I cost me a hole lot more than new tires. Also the last pair of BF T/A, were twenty years old, looked great on the outside, no cracks, and good thread. When taken off, I looked at them, and the inside were all bubbled.
My Goodyear SRS tires on my '77 Cutlass are dated 1992. They are in great shape with lots of tread left but............. I am concerned about separation on the highway. Cheaper to replace tires than straighten a car frame. I hear 6 years is about it. This afternoon I am getting them changed out to Hankooks I ordered from WalMart.
Check out this thread:
https://classicoldsmobile.com/forums...ese-tires.html
A lot of good information from a few months ago.
Kenneth, you still have 10's of miles left on those. On a side note, I just bought an 07 Mustang GT with only 7800 miles on it and original tires that of course look like new. I'll probably change them Labor Day weekend if there are some good sales.
My radial T/A's have been on my Cutlass since 2004.......tread is getting pretty minimal but they look cosmetically new. My car only sees the sun at shows.......other than that its in the garage. Because of the treadwear I'm getting new tires for next season, but I'm interested to see if there's any internal bubbling
Edit, the tires on my 4 speed Jetfire are from our automatic car, Not the tires from the "barn find" pictures of our 4 speed car that can be found, lol
The tires on my 71 98 are about 8 years old. I suppose I should replace them but they definitely still look new on the outside.
When I bought my 64 98 one of the tires blew out when I was on the test drive. I still bought it though.
I bet there will not be... IF there is ever a problem it is usually a separation issue. As long as the tire is in good condition and not been in the sun and abused then I don't worry about them. I am running on a set of tire on my 4 speed Jetfire that were bought in 1985. These tires were always garage kept and the car on jack stands when not used. Not a weather crack to be found anywhere and the rubber is still nice. This subject comes up about one time a year.
I pulled 16 year old BFG Radial TAs off my Monte Carlo this summer before the power tour. I kept the two dismounted ones (I have 6 wheels and kept two mounted as spares.)
They had 21,000 miles. The tread was good. There was no cracks. The inside looked good. Around the whitewalls the rubber was a little more matte than glossy, and I
blame that on whitewall cleaner and a wire brush. I think I will use a softer brush to whitewall clean on the new ones. I put 4 new ones on 2 of the rims that had the original BFGs and two that had 30 year old Michelins (and tossed the Michelins.)
I can attest to this. I had an old set of BFG TAs on my car and they started to get some slight cracks on the sidewall shoulder, but other than that seemed OK and I didn't have any issues driving around town. I got on the highway and within 3 miles a section of tread separated from the tire. The tire still held air but was missing about a 12" section of tread.
As I mentioned above, I did not trust my 26 year old tires on the highway. just changed to Hankooks yesterday. Very happy and more relaxed now. Nice smooth ride. By the way, how long would you run engine belt? I bet most people would not wait very long if they had any doubt. I just put a new set because I had no idea how old they were. The alt. belt was losing some outer material in a couple of spots. I know there is a big difference in cost between the two but both can do some real damage if there was failure.
Like I have posted before, Some companies recap tires that are more than 10 years old. Sure, they go through major testing but still, If age only was that devastating there would be DOT restrictions. I have had old tires blow out on old junkers on back roads but I knew those tires were junk. Sure, if you don't know and unsure, just replace them.
My 4 speed Jetfire still has the original 1962 belt on it (and plug wires). It is hard as a rock but still works great. Don't think I would take that car on a long trip with it, lol.
