Tilt column
Old Feb 12, 2019 | 05:00 PM
brandon reynolds's Avatar
Tilt column
Guy says it olds does anyone know what year this is thanks Brandon
Old Feb 12, 2019 | 05:09 PM
Rocketbrian's Avatar
The levers are from 71 and up Oldsmobile, but the bracket/plate that fastens to the inside firewall is not from a 70-72 A body. So most likely 73-77 if from an A body. I don't know when they went to the high beam switch on the column. Others will probably be able to give you more info.
Old Feb 12, 2019 | 05:24 PM
The column in my 69 came from a 75 Olds Cutlass. Swap the floor mounting plate, disconnect the dimmer switch on the floor, and plug in the dimmer jumper. I swapped the lock cylinder and hazard light button to the 69 parts for a more original look. Other than that, it’s a easy swap
toymobile
Aug 8, 2020 11:29 AM
brandon reynolds
Mar 15, 2019 02:06 AM
Cincinnati Rick
Nov 13, 2018 03:26 PM
oldgold
Mar 25, 2013 07:31 AM
andyman
Jul 25, 2012 03:09 PM
