throttle ques
Old May 16, 2010 | 07:27 PM
ELECMAN's Avatar
throttle ques
When im under 20 miles an hour and gun the pedal i feel like the car doesn't want to go it starts to putt putt but when i step on the pedal normal everything works fine. Got a 455 motor with a quadrajet 4 barrel 7042251 just rebuilt with the oia hood
Old May 17, 2010 | 05:25 AM
Lady72nRob71's Avatar
Accel. pump not working / misadjusted? Vacuum leak somewhere? Sounds like it is starving for fuel...
Old May 17, 2010 | 06:22 AM
MJAKS462's Avatar
Vacuam Advance ??
Old May 17, 2010 | 06:56 AM
Blk71SX's Avatar
Originally Posted by MJAKS462
Vacuam Advance ??
no
it's a major air/fuel mixture problem. open vacuum port, loose carb mounting, accelerator pump inoperable, transfer slots clogged, vac secondaries opening too soon. the list goes on and on
Old May 17, 2010 | 02:02 PM
ELECMAN's Avatar
The other thing was an HEI distrub was installed,it had an vacuum line coming out of the vacuum advance on the HEI going directly to the intake,my mechanic took it out and put it to the carb ,said something that it was to advance all the time thats why he did that,does this make sense.The motor was built from the block up everything new no used parts it was built by the old owner mechanic a top texas motor man.
defiant1
Feb 4, 2020 08:53 PM
ELECMAN
Feb 20, 2010 08:29 AM
ELECMAN
Feb 17, 2010 07:23 AM
ELECMAN
Feb 13, 2010 03:08 PM
ELECMAN
Nov 30, 2009 09:26 AM
