throtle position sensor 84 cutlass 5.0
Old Oct 22, 2016 | 12:51 PM
biogenic's Avatar
My engine light keeps coming on for a few minutes everyday. I jumped the obd and the code flashed #21 which is the TPS
I am trying to locate it and can't seem to see the rascal... can you guys point me in the right direction ?
Old Oct 22, 2016 | 03:04 PM
Welcome. The TPS is built into the carb and is located under the accelerator pump lever.
Before doing anything, you need to determine if the problem is the switch or the wiring that leads to the switch. I STRONGLY recommend that you get a copy of the factory Chassis Service Manual. The computer controlled Qjet works well if adjusted properly, but you MUST follow the adjustment process in the CSM exactly. Failure to do so will only result in wasted time and money. Good luck.
Old Oct 22, 2016 | 08:58 PM
biogenic's Avatar
Many Thanks Joe.
toymobile
Jul 9, 2015 01:34 PM
toymobile
Jun 27, 2015 06:11 PM
D Appeldorn
May 26, 2011 10:08 AM
mont1le
Feb 8, 2010 04:50 AM
