Thought it blew up!
Old Feb 18, 2014 | 08:16 AM
tru-blue 442's Avatar
Old School Olds
Thought it blew up!
Hey fellas, I haven't posted in
a few days, kinda down in the dumps
about the 400 E block coming apart.
I got a friend over this morning to pull the engine,
and came to find it was only the harmonic
balancer that blew apart. When I heard it
at about 35 mph pulling a small hill in town,
it sounded like a broke crank or a rod had come
loose. Shut it down, got my neighbor to tow it
home with my truck, and got on it today, whew!
Now onto my question, I have a used harmonic for
a 70 455 and one for a 67 330. Can I use the one
for the 455 to replace the one for the 400 E block?
I was farily sure the 330 one wouldn't work, but I need
your input guys. Thanks as always, Adam.
Old Feb 18, 2014 | 08:18 AM
Professur's Avatar
Only input I have is ... don't buy any lottery tickets this month .... you've used up your quota of luck. Glad to hear you got off easy.
Old Feb 18, 2014 | 08:26 AM
66400's Avatar
I'd use the 330 HB as a temporary fix. 400 and 425 use the same HB. 455 engines have different balance needs. 330/400/425 share the same flywheels/flex plates.
Henry
Old Feb 18, 2014 | 08:56 AM
Old School Olds
Thanks for the input Henry.
Have you an extra H/B
available? In the meantime,
I'm off to Granite Shoals to
see what shape the 330 is in...
Old Feb 18, 2014 | 08:59 AM
Old School Olds
This was my Valentine's day gift.
Happened on the 14th. Right before
we were to go for supper.
Old Feb 18, 2014 | 09:13 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Do yourself a favor and purchase a new fluid damper. A used OEM will likely do the same thing. People dont realize these are wear items and should be replaced periodically. You could get a new OEM but the fluid dampers are nice if you have a few extra pennies.
Old Feb 18, 2014 | 09:28 AM
NDERISE's Avatar
Thumbs up Dorman
Dorman has them ck with your local parts house part #594-117
this is a band new one, hope this helps
ray
Old Feb 18, 2014 | 09:38 AM
Octania's Avatar
The 330 unit should be a closer match but it would have to be a 4-bbl engine.
How about re-rubbering the original?
Where are all these NOS OEM E400 / D425 balancers?
Old Feb 18, 2014 | 09:50 AM
dc2x4drvr's Avatar
Question, does the 330 balancer have rubber in it? I sold one a few years ago, and thought it was solid..
Old Feb 18, 2014 | 10:49 AM
tmaleck's Avatar
Glad to hear it wasn't too bad after all.
Tim
Old Feb 18, 2014 | 10:55 AM
steverw's Avatar
I put a professional products balancer on mine, havnt run it yet but it should be ok. If I were you i would get an after market balancer have it neutrally balanced and use it!
Steve
Old Feb 18, 2014 | 12:54 PM
Old School Olds
Quick update guys. send my bud up
to the store for another 12, you know.
I am going to use the h/b from my son's
old engine, 66 330 4 bbl. out of his Cutlass.
As Henry shared, same part. Bead blasted
and painted using Tamraz crappy Olds bronze.
It was left over from the 69 455 rebuild for the
stalled 442 project.
If I can keep my dadgum foot out of it,
I can make that 48 yr. old rubber last a
while longer. Untill I can figure out which
new one to order. Thanks for the comments
guys. Here's a few pics...
Last edited by tru-blue 442; Feb 18, 2014 at 01:00 PM. Reason: Pics didn't take, now he's back.
Old Feb 18, 2014 | 12:58 PM
Professur's Avatar
I hope you at least got a little sympathy lovin' over it.
Old Feb 18, 2014 | 02:22 PM
oldsmobiledave's Avatar
Professional Products Balancer
Steve
Do yourself & pull it off & throw it away. Mine lasted less than 100 passes down the quarter mile before it spun on the rubber. Never again.
Old Feb 18, 2014 | 02:59 PM
Old School Olds
Good to go for now.
Hood on and gone to town.
Supper at Chili's.
Old Feb 18, 2014 | 03:12 PM
sammy's Avatar
Sammy70 455 Supreme
Glad it worked out for you Adam.
Assume you made it back from supper!
Probably will have taken you a little longer since you would not have had your foot into it
Old Feb 18, 2014 | 03:27 PM
Wow, glad it wasn't anything really serious.
Old Feb 18, 2014 | 04:30 PM
66400's Avatar
The 2bl 330 just had a hub with no outer ring. The 4bl 330 received the full rubber sandwich balancer.
Old Feb 18, 2014 | 04:49 PM
i agree with this. There are a couple of places that can rebuild your original.
damper dude
damper doctor
One of them is supposed to be good, the other may be iffy.
The problem is I can't remember which is which.
Old Feb 18, 2014 | 07:20 PM
edzolz's Avatar
Adam, the same thing happened to me when I lived in Richardson. I was driving my sons 67 442 and all hell broke loose. I shut it down and pulled off on a side street to look at what happened. Luckily there was no damage, like yours all it did was ring around on the hub. After I got another one on it, It had a very weird hum sounding like it was from the engine. Never could find the source. Completely went through the engine with new parts, still hummed. Just decided to live with it. Years later I had to replace the heater core and guess what. no hum. Still a mystery to me what caused it.
ajschirling
Oct 7, 2012 04:33 PM
SolowOne
Jul 16, 2012 09:39 AM
442b
Oct 24, 2011 07:38 PM
jeffreyalman
Nov 23, 2009 11:09 AM
