Thorton OAI hood
Old Feb 13, 2019 | 06:13 AM
JSOlds's Avatar
Thorton OAI hood
I am considering installing a OAI hood on my car and have heard about Thornton Hoods. Where can I find them for sale?
Old Feb 13, 2019 | 06:58 AM
tru-blue 442's Avatar
Old School Olds
http://thorntonmusclecars.com/produc...e-ram-air-hood
Old Feb 13, 2019 | 10:14 AM
Joffroi's Avatar
Runner
Did they ever make 71-72 hoods?
Old Feb 13, 2019 | 10:57 AM
droptopron's Avatar
delete
They did. If you call them they might be able to give you an idea if they'll be getting another batch
Old Feb 14, 2019 | 05:12 AM
rand5204's Avatar
I recently spoke with both Thornton and Fusick (who sells their hoods) and was told by both that the mold they use had been "damaged" and would take probably a year or so to repair. Both are out of stock on '70 hoods and will be for at least that long. It seems likely, given the differences that the 71/72 hoods probably use a different mold though so call and check with both. BTW, the new price will be $2,995
Old Feb 14, 2019 | 05:39 AM
friesjh's Avatar
Do Thornton hoods match the OEM hoods in the way they look, fit, etc...?
Old Feb 14, 2019 | 06:38 AM
jensenracing77's Avatar
They have the best repop hood out there. It is as close to original as you are going to get. The price reflects the better quality. In the short term, the originals started going up again because of them being out of stock
Old Feb 14, 2019 | 07:41 AM
VC455's Avatar
Barely Registered
My OEM hood would have required a lot of work to fit the fender profile. I bought a Thornton and it fit much better than my OEM hood, and it had much less mismatch at the front and rear corners. The painter said the swap saved about 60 hours of body work.
The only visual difference between the two was the wire mesh over the engine area. The mesh on the Thornton didn't have a binding at the rear. Otherwise the hoods appeared identical.
Old Feb 14, 2019 | 07:50 AM
rand5204's Avatar
VC455
Exactly right. I was able to buy one of the last available 70 Thornton hoods for that very reason. The blue 442 I did had as OE hood on it and my body shop had 50 or so hours into it to make it look good. At the end of the day, it's way more cost effective to use the Thornton hood regardless of the cost to buy.
Old Feb 14, 2019 | 08:56 AM
friesjh's Avatar
Great info, thanks all!!
Old Feb 14, 2019 | 09:46 AM
Originally Posted by rand5204
VC455
I am surprised at this. My body guy has used one and also used a couple original hoods. He said the Thornton hood was very nice but needed some work. He said he preferred using an original as long as it is not broken up or rusted out. I do know that both of the originals he used did match the fenders really well. Some of the originals do sag a little in the middle on the passenger side.
Old Feb 14, 2019 | 12:49 PM
Gerald Nickels's Avatar
On the factory hood along the sides its a V but on Thornton's hood its a square along the side.
Old Feb 15, 2019 | 05:11 AM
JSOlds's Avatar
OAI Hood
Thanks for all responses. One more question: Has anyone had experience with Fiber Concepts' or Tamraz's bolt on OAI hoods?
Old Feb 22, 2019 | 03:01 PM
coppertopgmc's Avatar
I called Thornton and asked about the 71-72 hood, they told me it could be at least 6 months or more before they start doing hoods because they are waiting on the metal to stamp the lower structure.
BSiegPaint
Sep 6, 2018 02:15 PM
67442nut
Jun 21, 2016 06:16 PM
my72olds
Aug 21, 2015 04:11 PM
GINCSC
Feb 5, 2015 11:53 AM
Vader
May 20, 2014 12:25 PM
