Thornton exhaust manifolds..... gaskets ?
Old Mar 18, 2013 | 10:59 AM
squirell's Avatar
Govt slave
Hi guys,
I just got some new repop exhaust manifolds from thornton ( w & z).
They say I don't need gaskets but can use them if I want.
I have the gaskets.....anyone use/not use gaskets with these and
does it leak ?
Old Mar 18, 2013 | 11:08 AM
Rickman48's Avatar
I've had better luck re-tightening bolts with lock washers than using gaskets - I've had gaskets blow-out.
Old Mar 18, 2013 | 12:21 PM
The factory didn't use gaskets. If the repro manifolds are as flat on the mating flange as originals, there's no reason to use gaskets. On the other hand, the gaskets won't really hurt, either. It's just more scraping if you ever have to take the manifolds off.
Old Mar 18, 2013 | 12:27 PM
jensenracing77's Avatar
I don't use gaskets either if the surfaces are nice. If you have gaskets now and you then don't use them, Make sure you get all the old gasket off before mounting them.
Old Mar 18, 2013 | 01:27 PM
tecar442's Avatar
I have Thornton manifolds and I didn't use gaskets. No leaks, fit great.
Old Mar 18, 2013 | 02:05 PM
11971four4two's Avatar
MOTORHEAD
I wood lay them down on a known flat surface and the evaluate the day light 4 yourself
buck50
Old Mar 18, 2013 | 03:43 PM
My442's Avatar
SCE copper gaskets work great.
Cheap insurance.
Old Mar 18, 2013 | 03:54 PM
bowtiebrad's Avatar
I'm gonna put some coppers on my original manifolds. Heard they work really well, last forever and can be reused multiple times. We will c
Old Mar 19, 2013 | 07:35 PM
squirell's Avatar
Govt slave
Thanx for all the input guys.
I'm gonna try the copper gaskets..can't hurt,won't stick
jensenracing77
Oct 11, 2020 03:32 PM
StickW31
Jun 29, 2015 03:46 PM
yankees
Jul 23, 2014 11:52 AM
woodie582
Dec 21, 2012 08:21 AM
76oldswarrior
Sep 1, 2012 05:59 AM
