Thinking of buying this 67 convertible
Old February 9th, 2013 | 07:52 AM
72cuttthang's Avatar
Im considering buying this 67 convertible. Just needed some opinions on the asking price and condition of the car. Comes with complete interior kit and brand new top all in the box. no motor no trans or hood. He's asking $3000.
Help!
Last edited by 72cuttthang; February 9th, 2013 at 07:55 AM. Reason: adding pictures
Old February 9th, 2013 | 07:57 AM
pictures
Heres the car
Old February 9th, 2013 | 08:10 AM
The price is right.
Old February 11th, 2013 | 08:31 AM
tmaleck's Avatar
The price may be right, but the metal will require a lot of work since he let sit unprotected and rust. Unless you are body and paint master, I would pass. I bought my 67 convertible running with a solid body for 8k. Deals are out there.
Originally Posted by 72cuttthang
Heres the car
Old February 11th, 2013 | 09:19 AM
Oldsmaniac's Avatar
Wow, not a 3 G car in my book. Check the condition of the frame. If its good offer 1000 and if he doesnt take it walk...I doubt anyone else would offer more.
Old February 11th, 2013 | 10:04 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
IMO $1000-1500 maybe 2k tops for a roller and thats if the frame, floors and all inner structures are in tact, sound and desert dry....
Check the dash & cowl area under the windshield and above the wipers remove the wiper grill and look under it . Check where the cowl mounts to the frame. Check the trunk & rear wheel tubs & trunk extensions, up where the vert top stows, vert top supports, radiator core support, all metal seams on doors trunk lid etc...
Only way I'd pay even close to $3000 for this car is if it was a sun baked desert dry car with surface rust, surface rust I could break off with minimal DA sanding. That body will take a great deal of metal prep just to get it ready for primer if its as bad as it appears.
Here is what the owner is most likely thinking....500-1000 for the shell and he probably has 1500ish in new parts. So if its desert dry then 2-3K isn't highway robbery. 1500 would be a good deal for you.
Old February 11th, 2013 | 10:10 AM
tru-blue 442's Avatar
Old School Olds
Well put Dr. O.!
Old February 11th, 2013 | 10:59 AM
ent72olds's Avatar
Registered Luser
Pass......
Old February 11th, 2013 | 12:25 PM
65B01Delta's Avatar
Pass... Way too much work there !
Old February 11th, 2013 | 12:59 PM
droptopron's Avatar
delete
If a picture is worth 1.000 words, well, those aren't. Not much to go on. Is there a trailer full of missing parts that go with it? Even if that answer is yes $3K sounds like a stretch IMO.
spiderjason
December 1st, 2010 11:33 PM
64Olds98
August 25th, 2010 05:19 PM
crumps
October 20th, 2008 02:12 PM
Nay-Sayer
Aurora
September 2nd, 2008 04:17 PM
Oldsprepp
June 4th, 2008 11:23 AM
Quick Reply: Thinking of buying this 67 convertible
