Things that make you go "hmmm"🤔🤔🤔
Old Oct 9, 2020 | 04:42 AM
72455's Avatar
1972 U code Supreme
On a '72 Supreme coolant reservoir, how does the coolant return to the radiator if there is no bottom return hose? And if it doesn't return to the radiator, then why is there an "add" and "full" level on the reservoir?
Old Oct 9, 2020 | 05:21 AM
The cap opens or releases when the pressure gets too high and coolant goes into overflow tank. On cars before the overflow it just went out tube and was lost. Then after car is shut off and coolant pressure drops radiator cap lets coolant come back thru tube into radiator. Thats why you need a cap that is made for a overflow tank- most are. When you remove the overflow cap, there is another tube that goes down into the tank isn't there? Should be.
Old Oct 9, 2020 | 05:23 AM
The same way the windshield washer tank can feed washer fluid from the cap. There's a tube that runs from the cap down into the tank.
Old Oct 9, 2020 | 05:31 AM
Well, now looking at your other thread I see you changed tanks. Is the second one supposed to be a original style? I can't tell if you have a tube inside the cap that goes down to about 1/2 " from the bottom of tank so it can siphon coolant back into radiator. If you don't have that no it won't work take coolant back into the radiator.
Old Oct 9, 2020 | 06:43 AM
72455's Avatar
1972 U code Supreme
It is the original style, and there is no tube going into the reservoir from the cap. I'll check tomorrow to see if I missed that on installation.
Old Oct 9, 2020 | 07:11 AM
The cap has got two barbs. One just goes through the cap and stops at the inside plane of the cap, the other has a barb on the inside. That one, with the channel with barbs on both sides, takes the hose to the radiator, and the 4 inch or so long hose to the bottom inside the jug. The other barb on the outside is the overflow hose, idea being is that jug will fill to MAX FULL in a "thermal event" and will start coming out the overflow (my money is it will blow the cap off).
PM70
Jul 15, 2019 10:49 AM
deadeyejedi
Jul 6, 2016 04:55 PM
Christophe2m6
Jun 21, 2015 03:23 PM
jpc647
Jul 5, 2013 06:07 AM
sicky olds
Oct 1, 2010 02:05 PM
