Are these drain holes or what?
My '70 CS Convertible got rained on pretty hard the past few days. When I backed out of the driveway I noticed a trail of water I've never seen before, so I found the source of where it was coming from which was a hole under the rear quarter just in front of the wheel. Though water was streaming out there seemed to be a slight blockage, so with my key I pushed on it and as it gave way oh yeah a river came pouring out. Same hole other side but, same blockage but more in tact, and no water. Are these drain holes? Should they be plugged? Not sure what to think or do about this, if anything.
Probably the top gutter drains. The plastic gutter under the top opening pinchweld routes water forward of the rear wheel wells where it runs down the inner body structure and out the drain openings. Fisher Body Manual should show it.
The openings are often plugged. Results in water building up in the body and overflowing into the rear footwells and armrests.
Ok thanks
Sunshn
October 20th, 2021 09:36 PM
