Thermostat housing
Old Mar 28, 2017 | 05:26 AM
Bfg's Avatar
Bfg
Thermostat housing
Is there any difference between thermostat housings from small block to big blocks on 65-70. Mine needs to be replaced due to corrosion. Would prefer original than after market. Thank you.
Old Mar 28, 2017 | 06:12 AM
oddball's Avatar
Same housing on all later gen (64 and later?) Olds v8's.
The only difference is the bypass tube. Some have a short straight tube - which then requires the formed rubber hose with the curve. Most housings have a bent metal tube so you only need a short section of heater hose to connect to the water pump.
Note that the Dorman and Chrome aftermarket parts are questionable at best and many folks have trouble getting them to seal. Post a parts wanted ad and folks will throw these things at you for a few bucks.
Old Mar 29, 2017 | 09:25 AM
Run to Rund's Avatar
There are slight differences year to year, and from AC/HD cool to non-AC. Are you looking for NOS? I have them for 1966.
Old Mar 30, 2017 | 04:39 AM
Bfg's Avatar
Bfg
Mine is a 65 442 with a/c. Not looking for NOS. just a good one. Is 66 the same for 65? Mine is mainly corroded where the by pass hose attaches.
Old Mar 30, 2017 | 07:03 AM
yes, according to the 11/71 parts book.
Old Mar 30, 2017 | 07:38 AM
CRUZN 66's Avatar
Olds Fever
According to the April 1969 parts manual a 65-400 w/air uses part number 392099, w/o air is part number 386129... This early style housing was available in both cast steel and aluminum, but I don't know what year the change was made or if it was relative to air versus non-air... In any case 65 & 66 housings should be the same...
Old Mar 30, 2017 | 07:43 AM
Bfg's Avatar
Bfg
Ok, thanks for getting back to me! I will check the number on the neck to see what I come up with. I won't be getting to the car until next week.
Old Apr 7, 2017 | 05:30 PM
Bfg's Avatar
Bfg
Cruzn 66 Is there a chance you have the part numbers for the a/c and the non a/c thermostat housings mixed up? The part number on my a/c thermostat housing is 386129. I believe the housing I have is original to my motor.
Old Apr 7, 2017 | 05:52 PM
Yellowstatue's Avatar
My 1974 book agrees with CRUZN. However my Nov. 67 book reads 386129 1965-67/all V-8 W/400 Engine...392099 1965-67/ All V-8 EXC 442 PKG.
Old Apr 7, 2017 | 06:48 PM
Bfg's Avatar
Bfg
I would like to see the difference between the two housings!
Old Apr 7, 2017 | 08:20 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Will post a pic of an early aluminum housing and a later cast iron housing tomorrow.
Old Apr 7, 2017 | 09:20 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Steer clear of the aftermarket junk...unless you want to replace it again next year. chineasium...nuff said.
Old Apr 8, 2017 | 09:06 AM
CRUZN 66's Avatar
Olds Fever
No, the numbers are correct according to the parts book... But based on the Nov. 67 book mentioned above. maybe that is where a change occurred for cast vs. aluminum... Sometime after that it was reverted back to cast, as may be referenced by the 74 parts catalogs... If anyone has 392099 and it is aluminum, that should verify what I suspect...
Old Apr 8, 2017 | 03:03 PM
Chesrown 67 OAI's Avatar
the angle of incline is a bit different -- thats all. either one will work fine on a non-tri-carb engine.
Some have a big 1 and some have a big 2 cast in the side. Either will workfine on your 65 car. The ones with the curved tube coming out of them are from later years - not sure which year they started but i know it was after 67? JoeP??
Old Apr 9, 2017 | 12:07 AM
Ozzie's Avatar
More confusion?
Just to add a bit more chaos to the confusion, here's what the 1966 Olds parts book (effective April 1966) has for group 1.153, Outlet, engine water, for the 8 cylinder engines:
1966-F85 V8, J88 exc. 442............................................... ....392099*
1966-F85 442, D88, Delta, S/F, 98 exc. C.A.C., Spec. Cool.......386129*
1966-F85 442, D88, Delta, S/F, 98 C.A.C., Spec. or H.D. Cool...392099*
1966 Tor. exc. C.A.C............................................. 382543*
1966 Tor. C.A.C............................................. .................393286
*The first four of the listing indicate that they were used on previous years also.
Old Apr 9, 2017 | 03:30 PM
tangokilo's Avatar
I would like to know why two styles too? I have two motors I pulled from 1970 Lansing built cars. A 70 delta 88 455 iron thermo housing. A 70 455 toronado aluminum housing? 30 years later I wish I had both back. Both were rusted beyond belief. The toronado at 65k was so bad the rear suspension failed...
Old Apr 9, 2017 | 04:38 PM
the 099 housing has a restrictor in the bypass nipple; the 129 does not. AC and HD cool cars had different pulley ratios and impellers in the water pump, hence the restrictor.
Old Apr 10, 2017 | 12:17 AM
Ozzie's Avatar
I suppose that's why people who live in areas where they salt the roads and the bridges NEVER drive their "good" vehicles in the winter.
projectheaven
Jul 3, 2019 07:16 AM
J'ville
Sep 24, 2010 02:30 PM
StickW31
Mar 2, 2010 03:39 AM
mont1le
Feb 7, 2010 08:23 PM
metro411
Dec 27, 2007 11:10 AM
