th400 duel gate shifter holder
Old November 17th, 2017, 04:54 PM
W30
truckman5000's Avatar
70 th 400 have a hurst duel gate.
The shifter will not go into 1st
the bracket on the transmission seems to be too short for the correct shiftier/ cable.
Does the auto / duel gate have a different bracket that mounts on the transmission?
truckman5000 is offline
Old November 18th, 2017, 04:28 AM
toymobile's Avatar
No, The brackets are the same, The end of the cable should be adjustable if original equipment.
Johnny
PS the transmission end of the cable.
toymobile is offline
Old November 18th, 2017, 06:47 AM
TripDeuces's Avatar
Did you use an aftermarket shift lever on the gear selector shaft?
I did with my DUAL gate and the slot is too short to allow proper adjustment of the cable to get it into low or 1st gear. I took a Dremel to it and lengthened the slot about 3/8 inch
TripDeuces is offline
Old November 18th, 2017, 05:39 PM
W30
so is there a diferent trans bracket for a auto only vs duel gate
Old November 18th, 2017, 10:21 PM
Gerald Nickels's Avatar
The bracket that is bolted to trans has a nut that can be moved so cable will fit. They make different 400 trans brackets.
Gerald Nickels is offline
Old November 19th, 2017, 06:02 PM
W30
the cable I took out is 20 inches apart were the cable bolts up to, with a 30inch total cabel legnth.
the new cable from the parts place is 18 inches , same 30inch total length.
I'm thinking my trans was swaped/ meeting the bracket to hold this cable is too long by 1.5 to 2 inches.
kinda like I have the wrong bracket at transmission.
Old November 19th, 2017, 06:55 PM
steverw's Avatar
Call Shiftworks 702-895-6812, Google them.
steverw is offline
w31man
November 2nd, 2014 07:18 PM
jensenracing77
November 2nd, 2014 04:29 AM
Dale Von Krosigk
October 1st, 2013 01:54 PM
jensenracing77
May 28th, 2009 07:21 PM
Quick Reply: th400 duel gate shifter holder
