TH 350 Question
Old Jul 8, 2015 | 12:38 PM
67Rocket's Avatar
TH 350 Question
What length tail shaft on TH 350 would be the same overall length as a Jetaway 2 speed? Thanks!
Old Jul 8, 2015 | 01:20 PM
toymobile's Avatar
Short, should bolt right in, Good Luck.
Old Jul 8, 2015 | 02:07 PM
Actually, it WILL bolt right in. This is about the easiest trans swap there is. The only issue is the kickdown cable. The 67 cars don't have the through-the-firewall provision that the later ones do. You'll need to go with an aftermarket cable and bracket.
falconsfan
May 14, 2015 05:47 AM
dharlett
Sep 23, 2009 03:30 PM
Jokers69
Oct 5, 2006 03:00 AM
<Eddie>
Nov 1, 2005 07:30 PM
