In take manifold
Old Mar 15, 2023 | 08:47 AM
deadeyejedi's Avatar
In take manifold
I think I’m going to pull the performer manifold and go back to the original cast iron manifold that was on my 1972 cutlass . I doubt I’m getting much if any performance out of it anyway and would like to get back to original, since the car has its matching numbers motor. My question: what numbers can I look at to determine if this is in fact the original manifold? Or does it even matter? Thank you
Old Mar 15, 2023 | 08:55 AM
If it weighs over 50+ lbs..it's likely original.
I don't honestly know the correct answer to your valid question; I'm indoors dodging the cold weather.
Not sure if this pic will help but here is the intake manifold in question
Old Mar 15, 2023 | 08:59 AM
my hernia guage tells me it’s 50 pounds 😂.Been digging out here in upstate ny from our latest visit from Mother Nature .
lunaboy's Avatar
The Rocket Astronomer
intake
404520 '70
398583 '70-'71 350 2V. Iron.
407564 '71 350 2V. Iron.
12 407565 '71 350 4V. Iron.
4085520 '71 350 4V. Iron.
13 410670 2V. Iron.
14 410446 '72
Old Mar 15, 2023 | 09:00 AM
lunaboy's Avatar
looks like the original !4 for 72
Old Mar 15, 2023 | 09:01 AM
Originally Posted by lunaboy
404520 '70
13 410670 2V. Iron.
14 410446 '72
perfect ! That’s what I needed thank you
Old Mar 15, 2023 | 09:08 AM
A tad more information than you most likely want to consume. I employed this article when evaluating my own intake manifold (1971 CS 350). Co-Authored by CO Member Joe Padavano...
Intake Manifolds 1964 - 1990
Old Mar 15, 2023 | 09:35 AM
lunaboy's Avatar
5th digit - Engine code - H = 350-2bbl V8 160hp
J = 350-2bbl V8 175 hp (dual exh.)
K = 350-4bbl V8 180 hp
M = 350-4bbl V8 200 hp (dual exh.)
U = 455-4bbl V8 250 hp (dual exh.)
V = 455-4bbl V8 270 hp (dual exh.)
X = 455-4bbl V8 300 hp (W30)
More info...if your cars vin in 5th digit has a K or an M you know it was born with that 4 barrel intake and not the 350 2 barrel.
Old Mar 15, 2023 | 09:57 AM
yes has the k vin 180 hp variety
Old Mar 15, 2023 | 11:36 AM
There is nothing on the intake that will prove it's the original. The best you can do is verify that it is the correct casting number and has a casting date within the range appropriate for the build date of your car. 410446 is the correct casting number for a 1972 4bbl 350 motor. That 246 casting date corresponds to Friday, Sept 3, 1971. That would be a reasonable casting date for a car built between mid-Oct 1971 and early Jan 1972. What's the assembly date on your cowl tag?
Old Mar 15, 2023 | 11:53 AM
Old Mar 15, 2023 | 11:56 AM
So if if my cowl tag memory serves me this car was built forth week of September?
Old Mar 15, 2023 | 11:58 AM
Fourth week
Old Mar 15, 2023 | 12:07 PM
Fourth week
thanks for the correction fourth weak👍🍺
Old Mar 15, 2023 | 12:16 PM
That's actually within the range. Usually components are expected to have date codes 1-3 months prior to the car's assembly date. Given that this is early in the model year, late Sept is also within the boundaries.
Old Mar 15, 2023 | 12:23 PM
Thank you
Old Mar 15, 2023 | 02:40 PM
I would keep the performer if anything just for the weight savings and the ability to cool faster after shutdown. It's probably a tad better over stock for performance. Put the cast iron back in storage for the next owner or sell it.
pfergy600
Mar 4, 2015 06:59 PM
billwaldo
Jan 6, 2015 05:34 PM
Skitch72
Jun 18, 2014 09:35 AM
wolfman98
Feb 6, 2009 03:36 PM
Southern_Hospitality
Mar 7, 2008 10:26 PM
