Stupid question. Be gentle
Old Feb 20, 2016 | 01:28 PM
asscutl's Avatar
I have a cutlass 350 with 7a heads. And a 600 edelbrock, duel exhaust. And about to put on a 2711 intake on. The guy down the street has c heads off a 455. He is selling for cheap. Is it a good idea to put this on my car. What can I expect? If it's a good idea what do you guys recommend. Ect
Old Feb 20, 2016 | 01:33 PM
2blu442's Avatar
Nope, you don't want to do that. C heads are big block heads and even though they will bolt up to the 350 block that will make your compression go way down. Unless you do a lot of work on the C heads they will not be an improvement for your setup. But if the price is good you might consider getting them for trade stock. John
Old Feb 20, 2016 | 01:35 PM
asscutl's Avatar
Thanks. The guy is selling for 50 bucks and says they need a rebuild
Old Feb 20, 2016 | 01:38 PM
2blu442's Avatar
Yeah, if they weren't cracked I'd snag them for that price. But then again, I'm an admitted Olds addict and will scan Craigslist looking for Olds parts to drag home.
John
Old Feb 20, 2016 | 01:46 PM
asscutl's Avatar
Heres the pic from cl<br/>
Old Feb 20, 2016 | 02:00 PM
2blu442's Avatar
Valve covers included? Kind of hard to see with the shadow, but valve covers on big blocks used in the Cutlass/442 bodies are "notched" Check out this thread for photos of what that looks like.
https://classicoldsmobile.com/forums...vers-sale.html
If they're not pitted the valve covers might be worth more than the purchase price. In addition, the breather looks like the early style. If these are 1967 heads they will have a stamp on the end of one head. If that stamp starts with a V then it was a 442 application. If it does that would add to the value of the head. John
Here's an example of the stamp on the end of one head.
Old Feb 20, 2016 | 02:31 PM
don71's Avatar
same but different
Those are early C's. see the small cross over port...
Worth 50 bucks if crack free. Just not for a 350 though, no gain with that swap.
Old Feb 20, 2016 | 09:44 PM
64Rocket's Avatar
They are '67 heads. See the "AIR" plugs in the heads.
Gene
Old Feb 20, 2016 | 10:14 PM
svnt442's Avatar
The valve covers are worth $50. Pick up the heads, keep the valve covers and use the heads for trade or resell them.
Old Feb 21, 2016 | 05:03 AM
deadeyejedi's Avatar
i have a set of 1970 olds 455 i think they are c's as well and my buddy insisted they would wake up my 350 but after listening to the all the expert advice here on co i scrapped the idea maybe some day they can be the start of a 455 build
Old Feb 21, 2016 | 05:12 AM
svnt442's Avatar
A heads were 65 and B were 66. C heads were 67-69 with D heads being W30 in 68 and 69. 1970 got E and F while 1971 got G and H. 72 went to GA and then 73-76 were J only on street car engines with K and KA heads being used on marine and equipment applications.
I'm pretty sure I got that right. Please feel free to correct me if I missed something.
Old Feb 21, 2016 | 06:19 AM
allyolds68's Avatar
Sold
When what zip are they being shipped too?
https://classicoldsmobile.com/forums/parts-sale/99078-stock-valve-covers.html
J/K but as you can see, stock non-notched valve covers aren't worth $50, not sure if they are even with $15.... Lol
C heads in any form except "cracked" are certainly worth $50 though.
BTW I thought only A-bodies got notched valve covers. Big cars were not notched because they didn't need the clearance from the A/C or brake booster.
Old Feb 21, 2016 | 06:57 AM
2blu442's Avatar
Gene
Ah, I should have seen that At the edge of the shadow it looks to me like there's a notch in that valve cover. If they were 1967 V code heads then I believe there should be one notched cover. So... if that's true its a good deal at $50 If the OP purchases them he'll have to fill in all these if's John
Old Feb 21, 2016 | 07:15 AM
svnt442's Avatar
Sold
Look closer...they are notched covers.
Old Feb 22, 2016 | 08:57 AM
67 442 heads are V#####G, I believe. Turnpike Cruiser 400s were V#####.
auto_editor
Apr 26, 2013 05:19 PM
MDchanic
Mar 27, 2012 07:54 PM
Tedd Thompson
Sep 24, 2010 07:32 AM
pedros 56
Aug 3, 2010 07:58 PM
gearheads78
Dec 18, 2009 06:15 AM
