stuck gas pedal
Old Dec 26, 2016 | 05:48 PM
1969CutlassSBlue's Avatar
stuck gas pedal
I just took the new 1969 Olds out for a spin and the accelerator cable stuck, spent half a minute doing a burn out pulling at the accelerator on the floor before I just shut off the ignition before the tires went. Any one know how to fix this?
Old Dec 26, 2016 | 06:30 PM
76olds's Avatar
Hookers under Hood
Check your linkages at the carb first of all, Has the car been sitting? Has the accelerator cable been stiff prior to the burn out?
When you manually pull the accelerator cable back to full throttle with the car off does the lower linkage grab the tab and not allow the cable to move back?
Which carb are you running?
Eric
Old Dec 26, 2016 | 06:34 PM
anthonyP's Avatar
Did you check throttle cable for any kinks, the return spring not properly attached, gas pedal or linkage stuck to anything, or possibly broken or loose motor mount?
Old Dec 27, 2016 | 03:57 AM
Cable failures are usually due to it fraying or corrosion inside the sheath. Check for smooth movement and lubricate. If it still binds, replace. Also check the return spring.
Old Dec 27, 2016 | 04:43 AM
rustyroger's Avatar
'87 Delta 88 Royale
If the throttle cable was stuck through lack uf use it might be wise to check out other linkages such as the parking brake and perhaps the inside of the drums.
Why didn't you simply turn the ignition off as soon as you realised you had a problem?.
Roger.
Old Dec 27, 2016 | 06:39 AM
Both times I've had a stuck throttle, it was due to the cable being frayed internally. They do wear our eventually. Easy to check - just disconnect from the carb and see if the cable moves freely.
Old Dec 27, 2016 | 09:10 AM
oldolds88's Avatar
caught on a floor mat?
Old Dec 27, 2016 | 10:07 AM
Kennybill's Avatar
Check for a broken drivers side engine mount.
Old Dec 27, 2016 | 12:38 PM
76olds's Avatar
Hookers under Hood
If he has a broken engine mount then the fan would likely be hitting the shroud making a lot of noise when accelerating. JMO
Actually now reading more suggestions,
I'll put my money on Eric and Joe's suggestion with a frayed cable under the sheath 1st.
Eric
Old Dec 27, 2016 | 01:28 PM
I'm not sure how a broken motor mount causes a stuck throttle with a cable style throttle. With the rigid metal rod used 1967-earlier, no question it's a possibility, but the whole reason GM changed from metal rods to cables was exactly this problem, due to the big broken motor mount recall in the late 1960s. Also, this car will have the interlocking style motor mounts anyway.
Old Dec 27, 2016 | 03:39 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
Be sure you have a oem cable.
My car had an aftermarket cable when I first got it,had the problem of a sticky throttle.
Replaced it with the oem type with the rubber grommet and nylon bushing and no more problems.
Old Dec 27, 2016 | 05:01 PM
anthonyP's Avatar
Eric
Good point, forgot about the shroud. Does his car have a fan shroud?
Old Dec 27, 2016 | 05:07 PM
76olds's Avatar
Hookers under Hood
If it has air then it should have a full shroud, no air then I would think just the small cover mounted on top of the rad sill with a caution fan sticker.
Eric
Old Dec 27, 2016 | 06:01 PM
anthonyP's Avatar
I'm not sure how a broken motor mount causes a stuck throttle with a cable style throttle. With the rigid metal rod used 1967-earlier, no question it's a possibility, but the whole reason GM changed from metal rods to cables was exactly this problem, due the the big broken motor mount recall in the late 1960s. Also, this car will have the interlocking style motor mounts anyway.
The motor mount problem was from 1965 to 1970. The 1969 and later A-body big blocks have the interlocking motor mounts, but the 1969 and earlier A-body small blocks still had the solid non-interlocking rubber mounts.
Remember seeing many recalled GM cars with safety chains installed by the dealership to "catch" the engine if the event the engine mount failed.
Gary M's Avatar
"Why didn't you simply turn the ignition off as soon as you realised you had a problem?."
Where's the the fun in that?
Old Dec 28, 2016 | 09:16 AM
rustyroger's Avatar
'87 Delta 88 Royale
I'm a grumpy old git who gets pleasure avoiding big bills. That's the fun I see.
Roger.
Joffroi
23
Apr 25, 2014 10:43 AM
blakes7
Dec 31, 2013 03:52 PM
My442
May 2, 2010 04:24 AM
jensenracing77
Feb 7, 2010 05:30 AM
64starfire
Jun 12, 2009 07:43 AM
