Stuck front brake drum?
Old May 21, 2017 | 08:00 PM
jcormier89's Avatar
Putting this here because somewhat urgent. I have a 56 Super 88 that has been sitting in my garage for about a year. It runs, but hasn't moved in that time. I am having it trailered to a mechanic next week to get some work done, so I pulled it out to clean this weekend.
I realized pretty quickly that the front passenger wheel is completely stuck and will not rotate. I assume this is a drum issue, but have never heard of a front drum getting stuck.
I can't get to the wheel as it is in the corner of my garage and there isn't enough space to work in. I've also thought about a wheel dolly, which could get me out of the garage, but there is a slight slope to my driveway--not sure how safe that would be.
Any thoughts would be appreciated, thanks!
Old May 21, 2017 | 08:48 PM
Tedd Thompson's Avatar
Well if you can't get to the wheel and you can't move the car you have a problem.
Have you tried to slide a floor jack under it from the far side? or lift the car from the middle, place floor jacks under it, slide under and ratchet the adjuster open. If that doesn't work try with side dikes reach over and cut the rubber brake line... Just a thought or two... Tedd
Old May 22, 2017 | 05:06 AM
X2 on what Tedd said.
Old Jun 2, 2017 | 12:29 PM
jcormier89's Avatar
Thanks both, much appreciated. Had a bunch of things going on so I wasn't able to get to it now. Going to try the adjuster first and cut line as a last resort. Adjuster access in the oval shaped hole on the very bottom of the drum, correct?
Any info on proper jack points for the 56? It looks to be the cross member right behind the oil pan for the floor jack and the part of the frame right to the rear of the front tires, but I wan't to make sure. I cannot find any diagram anywhere.
Thanks for the help, I am still very new to this Olds!
Old Jun 2, 2017 | 12:40 PM
Yes the oval shaped access point is where the adjuster is. You can Jack the car at the frame behind the wheel, cross member, or under lower control arm.
Old Jun 2, 2017 | 12:47 PM
toymobile's Avatar
Try rocking back and forth, that will usually free a stuck wheel, Has worked for me several times.
Hope this helps other wise what everyone else said
Good luck.
Johnny
Old Jun 2, 2017 | 01:08 PM
mpolds's Avatar
And, if you need -- I have N.O.S. Front Brake Drums, Front Wheel Cylinders, Front Brake Hoses, Front N.O.S. ++ Asbestos ++ Brake Shoes, Front Inner & Outer Wheel Bearings -- N.O.S. -- ALL Metal -- No Plastic, & Front Wheel Seals ---- EVERYTHING U.S.A. Made!!!!!!!!!!!!!!!!
Call Craig -- 516 - 485 - 1935 ..... if you need......Good Luck with the labor.
Old Jun 2, 2017 | 04:24 PM
Do not cut the line. That is not the problem and will just make more work for yourself. If you really, really think there is a hydraulic lock issue (and there isn't), then just remove the bleeder screw to relieve any pressure.
Get a wheeled floor jack. Jack up that corner of the car. Now push the car to where you can access the wheel and adjuster slot. If you can't get the adjuster backed off, cut or grind the heads off the brake shoe retention pins that stick out the back of the backing plate. This will release the shoes from the backing plate. Remove the spindle nut and outer wheel bearing and you'll be able to work the drum off, probably along with the shoes.
Kilmster
Brakes/Hydraulic Systems
Aug 6, 2014 05:41 PM
txrob779
Mar 1, 2014 07:42 PM
yeahbuddy
Jan 15, 2014 02:10 PM
1carsick
23
Oct 2, 2012 05:50 PM
jon69olds
Wheels and Tires
Feb 11, 2011 11:57 AM
