Stripping/cleaning aluminum?
Old Sep 10, 2009 | 05:35 PM
Cameo White's Avatar
Question Stripping/cleaning aluminum?
I have an original W-27 cover that someone painted black art some point. Other than that it seems to be pretty nice, with a small portion broken off one of the fins. Since it was on my car when I bought it, I'd like to clean it up, preserve it, and display it.
Any body have any experience safely stripping cast aluminum without damaging it?
Thanks.
Old Sep 10, 2009 | 07:08 PM
svnt442's Avatar
I'd start with brake cleaner in a bucket with a plastic bristled brush. You should be able to get most of it off with that I'd suspect.
Old Sep 10, 2009 | 07:51 PM
Dan Wirth's Avatar
I found an excellent Mag & Alluminum polish (Mother's Mag & Alluminum Polish) can get it at most auto stores. It's also great for cleaning/polishing chrome.
Old Sep 11, 2009 | 02:24 AM
jensenracing77's Avatar
find someone with a blast cabnet that has fine glas beed in it. it will come out looking new and it will not hurt the aluminum
Old Sep 11, 2009 | 08:24 AM
slowolds's Avatar
Loose Radical
I would use glass or soda blasting to not damage the soft aluminum. Preferred over chemicals.
Old Sep 11, 2009 | 09:23 AM
Bluevista's Avatar
Registered
Throw it on the ground in the backyard and leave it sit outside all winter.
No paint stays on any aluminum I do that with.
That brake cleaner may possibly work but is some nasty stuff.
I got rid of mine after reading gearheads post about the ultra-toxic dangers of it and welding/direct heat.
Bead blasting would probably be the best bet.
Old Sep 12, 2009 | 10:50 AM
Why not just sand it?
Old Sep 12, 2009 | 12:49 PM
mugzilla's Avatar
is Fast Enough ...
There are things like Walnut Shell that you can blast with ...
tocicar8825
Sep 21, 2021 07:10 AM
TexasGunner
Mar 29, 2014 11:14 AM
brent
Oct 3, 2011 07:47 AM
texasred
Apr 19, 2004 01:07 PM
