Steering Wheel Question
Hello All,
I just put a steering wheel from a 1974 Corvette on my 69 Cutlass. I didn't come with a horn button and Im not sure where or what kind of button I need to buy. Thanks
Yes the horn contacts are the same for alot of years and cars, again call Bair Corvette. The contact has a leg that presses the contact in your column, Im not sure if its clocked the same as a vette. Fusicks or other Oldsmobile specific dealers may be the best bet.
That horn button he is showing you should fit the contacts with no problem.
Just checked my Fusicks catalog part number HC677 $23.50, if you need a new horn contact plunger and spring it RWHC702 $5.00, a new center cap is RWC702 $74.50.
They have 2 numbers 1-860-623-4589, and 1-860-623-1583
The plunger/contact kit and the circular contact spring are the same for all GM steering wheels that use this spoke design. That includes the 68 Olds woodgrain wheel, the 1970-up four spoke wheels, and the three spoke woodgrain and colored wheels used by Chevy and Buick. The Olds and Buick horn buttons are the same except for the plastic emblem in the center. This can be swapped out with some careful prying.
And when you install the contact kit, be sure to put the spring in the hole first, then the eyelet, then the plastic ring to hold it in place.
RPMRestoAndCustom
July 16th, 2012 04:29 PM
GoodOldsGuyDougie
July 15th, 2011 07:00 AM
